Adds hosts
stryk
Adds hosts
Post by stryk »
I try to write a script that adds hosts, like this:
echo "9\n1\n2\nxa00001\n192.168.69.69\n0\n0\n18\n0\n" | netadmin -m
But this code don't work: "ERROR tcgetattr"
What's that ? :lol:
you have an idea to write it otherwise?
Thanks ^
sadim
Re: Adds hosts
Post by sadim »
Just add the host(s) to the hosts files.
tgn
Re: Adds hosts
Post by tgn »
sadim wrote:Hi,
not a good idea.
netadmin covers more than just entries in /etc/hosts
regards...
stryk
Re: Adds hosts
Post by stryk »
Hi Sadim,
I thought about it but /etc/hosts file is denied for mtcl account ... And my script run in mtcl !
Sudo don't work either ...
Else, yes this code work good in root user:
echo -e "192.169.69.69	xa00001" >> /etc/hosts
finally i'll use a correct command into rsh command for adds all hosts to all nodes.
tgn
Re: Adds hosts
Post by tgn »
stryk wrote: 20 Sep 2017 12:17 finally i'll use a correct command into rsh command for adds all hosts to all nodes.
trough netadmin? or trough echo "something" >> /etc/hosts?
regards...
stryk
Re: Adds hosts
Post by stryk »
One who work ^
I would like to work netadmin ...
sadim
Re: Adds hosts
Post by sadim »
check your private messages
stryk
Re: Adds hosts
Post by stryk »
Answered ;)
Return to “Linux tricks”
