Anyone out there using the Oracle Virtual Box as there virtualization solution who has managed to get R12 to load and run?
I am using M1.403.15.h which loads with PCINSTALLER ok but on reboot it crashes almost immediately, I have tried adjusting the memory and HDD specs but with no success.
No problems using everything upto R11.2.2.
Just wondering if anyone using Virtual Box has managed to overcome this?
K.
R12 on Virtual Box
- Krusty65
R12 on Virtual Box
Re: R12 on Virtual Box
not sure if this is the problem here, but try to turn off "nested paging" in cpu settings of the vm.
regards...
regards...
Just tried with Windows 10(x86) host. VirtualBox is 5.1.26 r117224 (Qt5.6.2).
I didnt managed to run PCInstaller natively in Win10 so I use PCInstaller (4.1) in VM( Win7 ).
So I noticed a few problems - linux.ram loads 10 times longer if comparing, e.g. R11.2. Also Linux files load in strange ways - progress bar freezes for some time then starts again from 0.
But nevertheless it's installed and running after restart.
Do you try VMware player? It works fine to me, and Alcatel VM are normaly based on VMware.
Enviado do meu Aquaris M5 através de Tapatalk
Best Regards
Jose Alves
Jose Alves
? VMWare player as the name suggests, just plays an already created VM. You can't create a new one there.
- Krusty65
Cav,
Turning off Nested paging worked, thanks, strange that this has not been a problem before.
Alex is this on in the machine that you got working?
K.
K.
- Krusty65
tgn apologies thanked Cav for you fix, thanks to you.
Hi what do you mean? It's on my working notebook.
no worries krusty [emoji6].
@alex - i think he means the option "nested paging". is it turned on or off on your virtual machine for oxe r12?
regards...
regards...
I see now. No, I didn't touch anything, so nested paging is checked on my VM.
