Dear All,
I am new in Omnix PCX enterprise, we are starting setup in our company.
When we try to perform dial to external number from company ( using public telephony company) , so system return acess denied,
anyone knows what can be , or what features i must check in mgr ?
incoming calls from outside (any external number from public telephony company ) are working well, just outbound calls don´t work
Thanks a lot
Fabio
External call doesn´t work
Re: External call doesn´t work
Public Network COS (if call denied by category),
or discriminator rules - if dialled number not exist in discriminator.
Don't expect a step by step as we don't know your discriminator, entities, category configuration.
Better ask the guy who did the installation until.you get a proper document from them or a basic training. You can mess with something that works.
fabiocorreia
Thank you Mr. cavagnaro and Mr. Vad, i will check what you told, do you have some
beginner instalation manual from ominix pcx, step by step ?
again,
Thanks a lot
again,
Thanks a lot
System documentation has good examples. Download it from the forum (search) and read it in detail.
fabiocorreia
Mr cavagnaro,
I checked in forum forum , but i didn t find anything,
i need document that explain beginners concepts, like entities, trunks, discriminator, and others
if you have something, could you send me ?
Thanks a Lot
Thanks a Lot
jdsanchez
Hi, I´m new and same as you, Ineed those manual of basic configuration please
There is no such thing as beginners concepts... you need system documentation as Cav said and practice and time!!!
