ACD OXO Agent Assistant can not make calls on Windows 7-10
aurelian
Post by aurelian »
Hello team!
We have an OXO Connect R2.1_037.001 with Call Center (ACD) licenses.
On the ALE business partner website I found only the application package ACD_10.2.0_10.100.01_XX_Alcatel.zip
The problem is that Agent Assistant can not make calls unless it is installed on Windows XP. On Windows 7 32-bit or Windows 10 64-bit, the call does not go away. The other functions seem to work.
The question is whether anything can be set in Windows 7-10 to be able to make outgoing calls from Agent Assistant?
fe80
Re: ACD OXO Agent Assistant can not make calls on Windows 7-10
Post by fe80 »
Please try to change the following registry settings in your windows client:
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\.NETFramework\v4.0.30319
"SystemDefaultTlsVersions"=dword:00000001
aurelian
Post by aurelian »
Thank you very much for your answer!
I can not test right now, but I hope it works.
Return to “Applications”
