Working Directory Boot problem
jp choudhary
Post by jp choudhary »
Hello everyone ,
After power failure my 6450 switch is booting form certified directory , i have tried some command s like setNextRunningVersion 2 cd certified but no success
after setNextRunningVersion 2 after this command i reboot the switch , then switch is showing the this
Init Phy port 1 .. Done
Power up GMII port0 .. Done.
Power up GMII port1 .. Done.
Detected DRAM size 256MB
Detect SysClk 320MHz
Detect Tclk 200MHz
Marvell Controller initialization Done.
Eth int Ctrl.... Done
GPIO int Ctrl... Done
PEX int Ctrl.... Done
PEX0 init....... Done. DEVICE type selected
USB Init........ Done
USB int Ctrl.... Done
XOR int Ctrl.... Done
XOR init........ Done
mvCtrlInit2..... done
PCI auto config. done
sysHwInit2...... DoneUSB2 Host Stack Initialized.
USB Hub Driver Initialized
USBD Wind River Systems, Inc. 560 Initialized
Non-PCI USB device found: pgmIf=0xa0, idx=0 , baseAddr=0xf1050100, irq=19, swapF
unc=0xa1abf4
EHCI Controller found.
Waiting to attach to USBD...Done.
0xffffe50 (tRootTask): usbBulkDevInit() returned OK
usbCbiUfiDevInit() returned OK
CBI Class Driver Successfully Initialized
CS EEPROM Module ID: 420122b3 , System type: Lite 6450 8 POE ports, 2 combo port
s & 2 fixed sfp stacking or uplink port - Kingfisher2
System Configuration
BSP Ver: 1.2/1.1.01 Creation date: Mar 22 2012, 00:07:53
CHIP : MV88F6281 Rev 2
CPU : ARM926 (Rev 1)
BOARD : DB-98DX4122-48G (0x7)
CLOCKs : tClk = 200 MHz, sysClk = 320 MHz
pClk = 800 MHz
NAT_SUPPORT = Disabled
VFP_SUPPORT = Disabled
FlashFX initialization required 799ms
File System initialization required 0ms
FlashFX initialization required 99ms
Target Name: vxTarget
Ethernet port #0 initialized
mgi0 Interface Loaded
mgi0 Interface Started
mgi0 Interface - Link Up, 1000 Full
Attaching network interface lo0... done.
Adding 8031 symbols for standalone.
Boot parameters are:
'flash(0,0)cmm:default e=10.4.50.165:ff000000 g=10.4.50.5 u=admin pw=switch cb=
9600 cp=none cs=1 cw=8 cm=modemControlOff'
AOS miniboot version: 6.6.3.259.R01
VxWorks (for DB-98DX4122-48G BE MMU ARCH 5) version VxWorks5.5.1
KERNEL: WIND version 2.6
Made on Mar 22 2012, 00:07:53.
Copyright Wind River Systems, Inc., 1984-2006
CPU: DB-98DX4122-48G BE MMU ARCH 5. Processor #0.
Memory Size: 256 MBytes. BSP version 1.2/1.1.01.
Portions of code copyrighted by Alcatel Internetworking, Inc. 1994-2012. All Ri
ghts reserved
Portions of code copyrighted by Apptitude, Inc. 1997-1999. All Rights reserved
Portions of code copyrighted by Free Software Foundation, Inc. 1989,1991. All r
ights reserved
Portions of code copyrighted by The OpenLDAP Foundation 1999-2000. All rights r
eserved
Portions of code copyrighted by Theodore T'so 1994,1995,1996,1997,1998,1999. Al
l Rights reserved
Portions of code copyrighted by RSA Security, Inc. All Rights reserved
Portions of code developed by the Carnegie-Mellon University.
Attempting to load from the WORKING directory...
Loading kernel from '/flash/working/KFos.img'..
7211712
Loade
Detected board DB-98DX4122-48G
Ctrl env init... Done.
CPU if init..... Done.
Done. Actual freq = 96153Hz
Memory on board initialized .
Init Phy port 0 .. Done
Detect Tclk 200MHz
unc=0x10abf4
BSP Ver: 1.2/1.1.01 Creation date: May 14 2012, 13:15:10
pClk = 800 MHz
Write Protecting exception Vectors
Write protecting KFos .text sections (0x100000 to 0x523000) 1059 pages
Adding 11926 symbols for standalone.
AOS kernel version: 6.6.3.372.R01
Made on May 14 2012, 13:15:10.
ghts reserved
ights reserved
eserved
l Rights reserved
The current date and time is:
Coordinated Universal Time (UTC): SUN DEC 31 01:00:03 2000
Local time: SUN DEC 31 01:00:03 2000 UTC
Starting dynamic software load from '/flash/working/'...
FIPS_text_start() returns NULL
Undefined symbol: isKF3P10Chassis (binding 1 type 0) loading eni.lnk
Undefined symbol: extDrvDragoniteMsgRead (binding 1 type 0) loading eni.lnk
Undefined symbol: is6350CP24Chassis (binding 1 type 0) loading eni.lnk
Undefined symbol: ledDebug (binding 1 type 0) loading eni.lnk
Undefined symbol: isKF2P10SChassis (binding 1 type 0) loading eni.lnk
Undefined symbol: isKingfisher3Chassis (binding 1 type 0) loading eni.lnk
Undefined symbol: isKF2U24SChassis (binding 1 type 0) loading eni.lnk
Undefined symbol: i2cReadDDMSFPPSep (binding 1 type 0) loading eni.lnk
Undefined symbol: _func_ssSetLastReboot (binding 1 type 0) loading eni.lnk
Undefined symbol: indexCpldReads (binding 1 type 0) loading eni.lnk
Undefined symbol: i2cReadPartialSFP (binding 1 type 0) loading eni.lnk
Undefined symbol: indexCpldWrites (binding 1 type 0) loading eni.lnk
Undefined symbol: _func_sysSetLastReboot (binding 1 type 0) loading eni.lnk
Undefined symbol: extDrvDragoniteMsgWrite (binding 1 type 0) loading eni.lnk
Undefined symbol: _func_pmdSetLastReboot (binding 1 type 0) loading eni.lnk
Undefined symbol: is6350C24Chassis (binding 1 type 0) loading eni.lnk
Undefined symbol: is6350C48Chassis (binding 1 type 0) loading eni.lnk
Undefined symbol: i2cReadDDMSFPSep (binding 1 type 0) loading eni.lnk
Undefined symbol: memStatsDumpIntoFile (binding 1 type 0) loading eni.lnk
Undefined symbol: cpldWrites (binding 1 type 0) loading eni.lnk
Undefined symbol: stopRecord (binding 1 type 0) loading eni.lnk
Undefined symbol: i2cReadPartialSFPSep_Phy (binding 1 type 0) loading eni.lnk
Undefined symbol: cpldReads (binding 1 type 0) loading eni.lnk
Undefined symbol: is6350CP48Chassis (binding 1 type 0) loading eni.lnk
Undefined symbol: isKF3C10Chassis (binding 1 type 0) loading eni.lnk
SUN DEC 31 01:00:14 : SYSTEM (75) info message:
+++ Switch Logging device '/dev/console' enabled for output
SUN DEC 31 01:00:14 : CSM-CHASSIS (103) info message:
+++ == CSM == === Chassis Supervision Starting Up ===
sysStartWatchdog() Starting watchdog timer to INTERRUPT after 240 secs.
esf=0xdfbba6c
SUN DEC 31 01:00:14 : SYSTEM trap message:
Task 0xdfbbaf8 (tNiSup&Prb) priority 40. trapped
Data abort : Permission Exception (Page)
Exception address: 0x00d8c038
Exception Fault Address Register: 0x00000000
Current Processor Status Register: 0x80000013 (Flags:N Mode:SVC32)
2e824c vxTaskEntry + 24: i2cCPLDWriteByte()
160124 i2cCPLDWriteByte + b8: nisup()
r0 = 0 r1 = d8bd44 r2 = 0 r3 = 0
r4 = 1 r5 = 44000000 r6 = 420122b3 r7 = 0
r8 = cf9172c r9 = 0 r10 = 0 r11/fp = dfbbab4
r12/ip = 0 r13/sp = dfbba84 r14/lr = 160124 pc = d8c038
cpsr = 80000013
00d8bfe8 0f6272c0 SWIEQ 0x6272c0
00d8bfec 013cc444 TEQEQ r12,r4,ASR #8
nisup:
00d8bff0 e1a0c00d MOV r12,r13
00d8bff4 e92dd9f0 STMDB r13!,{r4-r8,r11,r12,r14,pc}
00d8bff8 e24cb004 SUB r11,r12,#4
00d8bffc e1a05000 MOV r5,r0
00d8c000 e3a000f0 MOV r0,#0xf0
00d8c004 e1a04002 MOV r4,r2
00d8c008 e1a07003 MOV r7,r3
00d8c00c e1a06001 MOV r6,r1
00d8c010 e24dd010 SUB r13,r13,#0x10
00d8c014 ebcf5731 BL ssStartWatchdogTimer
00d8c018 e59f35d0 LDR r3,0x00d8c5f0
00d8c01c e3550311 CMP r5,#0x44000000
00d8c020 159f85cc LDRNE r8,0x00d8c5f4
00d8c024 15834000 STRNE r4,[r3,#0]
00d8c028 0a0000ff BEQ 0x00d8c42c
00d8c02c e59f15c4 LDR r1,0x00d8c5f8
00d8c030 e59f35c4 LDR r3,0x00d8c5fc
00d8c034 e59f25c4 LDR r2,0x00d8c600
00d8c038 e5831000 STR r1,[r3,#0]
00d8c03c e59f35c0 LDR r3,0x00d8c604
00d8c040 e3550315 CMP r5,#0x54000000
00d8c044 e5821000 STR r1,[r2,#0]
00d8c048 e5831000 STR r1,[r3,#0]
00d8c04c 0a000144 BEQ 0x00d8c564
00d8c050 ebffe823 BL nisup_spawn_nipmd_and_register
00d8c054 e3700001 CMN r0,#1
00d8c058 0a000135 BEQ 0x00d8c534
00d8c05c e1a03007 MOV r3,r7
SUN DEC 31 01:00:15 : CSM-CHASSIS (103) info message:
+++ == CSM == CS excep handler: exception 16 in task 0xdfbbaf8
+++ == CSM == Excep in task: tNiSup&Prb PC : 0xdfbb9b8
====> SYSTEM PANIC: WATCHDOG INTERRUPT <====
====> External interrupts stats <====
WD int count : 1
CPLD system intr cnt : 0
EXP mod intr cnt : 0
PWR fail int cnt : 0
Combo phy intr cnt : 0
Combo rxLoss intr cnt : 0
Writing PMD to flash ...size 312bytes and block 0
Writing PMD to flash ...size 729bytes and block 0
Writing PMD to flash ...size 1254bytes and block 0
Writing PMD to flash ...size 1465bytes and block 0
Writing PMD to flash ...size 3778bytes and block 0
Writing PMD to flash ...size 3841bytes and block 0
Writing PMD to flash ...size 3907bytes and block 0
Writing PMD to flash ...size 5191bytes and block 0
Writing PMD to flash ...size 25113bytes and block 0
Writing PMD to flash ...size 25653bytes and block 0
Writing PMD to flash ...size 28629bytes and block 0
Writing PMD to flash ...size 49286bytes and block 0
Writing PMD to flash ...size 131060bytes and block 1
Writing PMD to flash ...size 262132bytes and block 2
Writing PMD to flash ...size 315515bytes and block 2
Dumping sys trace to PMD
Writing PMD to flash ...size 373148bytes and block 2
Dumping ttall to PMD
Writing PMD to flash ...size 393204bytes and block 3
Writing PMD to flash ...size 404996bytes and block 3
Dumping application data to PMD
Writing PMD to flash ...size 419236bytes and block 3
Dumping spy report to PMD
Writing PMD to flash ...size 421973bytes and block 3
Completed PMD dump system rebooting...
====> SYSTEM REBOOTING <====
and after 1 minute switch again booting from certified directory
Certified: [Kernel]->
Re: Working Directory Boot problem
I see that you have a very old version 6.6.3.372.R01
There where big problems with this release. You can try with usb disaster recovery to install a new release (including format of flash). In sw-guide you will find the handling (or here in different posts).
Return to “OmniSwitch 6450”
