CLI issue from incoming call through oxe R12
shirantha
Post by shirantha »
please be update the issue as IDD incoming call . The incoming call appear through the 4059 operator console it shows OA00918039670000..
Please refer attached photo.
Thanks,
Shirantha
Re: CLI issue from incoming call through oxe R12
And what is your problem?
What you will see on set display depends of:
1 - received Calling number (for ISDN/H323 calls - you can check with t3 trace)
2 - external callback translator (you can adapt Calling number for your requirements)
3 - after this - you can have some problem comes f.e. from Speed Dial (if calling number after external callback translation will be found in SD - you will see "Displayed name" from SD instead of Calling number)
sadi_seemi
Post by sadi_seemi »
Hello
I also need help.....about DID Cli issue on incomming call....on another oxe node...
f.e. isdn DID pri terminated on oxe node 1.... All did of node 1 working perfect incoming and outgoing cli ok....but....DID of node 2 incoming call cli not display on set...outgoing cli is ok....
Node 1 and node 2 connected with ABCF configuration
External callback translation on node 2 - managed or not? At least - DEF
sadi_seemi
hi vad
yes your observation is correct...today i managed this cli working ok ...thanks
Best Regards
Return to “External Services”
