Call logs not showing received numbers in 80x8 series sets
HUSSAINQCS
Post by HUSSAINQCS »
I have an Omni Pcx Office system also newly installed but system is connected to Analog trunk when there is external incoming call to 80x8 series sets In call logs it was showing **** & not the number
HUSSAINQCS
Re: Call logs not showing received numbers in 80x8 series sets
Hi has anybody faced similar issue
timbrown
Post by timbrown »
Yes I'm facing the same issue with a 8039 set in an OXO Connect M system using 4 x analog trunks.
I also cannot see the incoming caller ID.
Tim
Usual analogue phone with CLI (connect to external line without OXO) - show or not calling number?
HUSSAINQCS
Thanks Mr.Vad ,
Actually the problem is when I try to retrieve the calls from the call logs at that time it was not showing instead showing ****
But it was showing while in conversation
Isn't there a taxation parameter to show numbers?
VAD may point it out
mdhussainvlr
Post by mdhussainvlr »
Hi is anybody have solution for this issue
mdhussainvlr
mdhussainvlr
It was not showing for unanswered call instead showing ***
solven
Post by solven »
Do theese phones have different rights profiles than the phones that don't have this problem? I remember seeing a paramater like this once, but I can't remeber where at the top of my head. Are the masked numbers internal, external or both?
Return to “Applications”
