weird Pimphony error boys and girls
R4.2 PIM on a 3.1 box - i install run the wizard, all seems ok, try to continue but the wizard comes back up and i have to go through it all over again.. cant move past this point.
Tried with my laptop but the problem persists, safe to say its not a PC issue.
I have checked licensing (1 license has been purchased), checked system but cant find my problem.. Installed PIMphony many times prior with no issue.
Cheers!
PIMphony Problem (Whats new?)
Avi1
Re: PIMphony Problem (Whats new?)
Have you installed Pimphony under the LOCAL ADMIN Account ?
Don't install with another account, this would cause strange problems !!
steg81_DUP
have you tried deleting the user and re-adding the user, doeas it happen with every user?
Jigger
If you mean the user on the PC, - I have tried to install using my own laptop and get the same problem.
If you mean on the OXO, - i dont get far enough into the install for this to be possible.
steg81_DUP
Mate,
I would recomend downloading a new installer of Pimphony.
