Good afternoon,
I just wanna do a script that send a single line one command into switch over SSH, but I cannot perform that, because only connect into the machine to let's start work with Alcatel devices.
I wanna get more information if Alcatel does have some API for web development or for this cases. Just Does It have?
Thanks!
API of switches, Web app...
Re: API of switches, Web app...
most informations about API you will find in the switch management guides.
sincorchetes
I just found information in AOS Release 7 and 8 management guides that talks about APIs, but for AOS6850 I didn't find anything contains API's related in AOS Release 6 Management Guide.
I don't think that the AOS6 based switches support netconf, but with
"perl Net::SSH::Expect" you can automate it for yourself. Just follow the CLI Guide
Otherwise setting parameters by snmp should work as well, you find the needed snmp Objects in the CLI guide as well.
David_Klancar
Good afternoon,
I made a python script for sending SSH command (multiple command separated with
and save all outputs in a file. I use the pexpect module; please find the script if needed:
#!/usr/bin/python
# -*- coding: utf-8 -*-
# Script : Send_SSH_Command.py
# Author : David KLANCAR
# Date : 29/01/2018
# Update : 14/02/2018 : Add multiple commands
from datetime import timedelta
import time
import os
import re
import sys
import copy
import subprocess
import pexpect
from argparse import ArgumentParser, ArgumentError
from functools import wraps
#### Functions ####
# Argument parser
# My own ArgumentParser with single-line stdout output and unknown state Nagios retcode
class NagiosArgumentParser(ArgumentParser):
def error(self, message):
sys.stdout.write('UNKNOWN: Bad arguments (see --help): %s\n' % message)
sys.exit(3)
# Nagios unknown exit decorator in case of TB
def tb2unknown(method):
@wraps(method)
def wrapped(*args, **kw):
try:
f_result = method(*args, **kw)
return f_result
except Exception, e:
print 'UNKNOWN: Got exception while running %s: %s' % (method.__name__, str(e))
if debug:
raise
sys.exit(3)
return wrapped
# Arguments handler
@tb2unknown
def parse_args():
argparser = NagiosArgumentParser(description='MAC Table entries')
argparser_global = argparser.add_argument_group('Global')
argparser_global.add_argument('-H', '--host', type=str, required=True,
help='Hostname or address to query (mandatory)')
argparser_global.add_argument('-N', '--name', type=str , required=True,
help='Switch hostname')
argparser_global.add_argument('--sshlogin',type=str , default='admin',
help='user used for ssh session')
argparser_global.add_argument('--sshpassword',type=str , default='switch',
help='password used for ssh session')
argparser_global.add_argument('--clicommand',type=str , default='show',
help='CLI command to execute')
argparser_global.add_argument('--clitimeout',type=int , default=3,
help='CLI timeout')
argparser_global.add_argument('--filename',type=str , default='',
help='Word to add in the file name if needed')
argparser_global.add_argument('--outputfolder',type=str , default='/Temp/',
help='Output folder - Example "/Temp/"')
args = argparser.parse_args()
return args
@tb2unknown
def assure_path_exists(path):
dir = os.path.dirname(path)
if not os.path.exists(dir):
os.makedirs(dir)
@tb2unknown
def sshSendCommands(IP,Login,Password,CLICOMMAND):
child = pexpect.spawn('ssh -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no %s@%s' % (Login, IP))
# output
SessionOutput = ''
child.logfile = sys.stdout
child.timeout = 10
# Enter password or accept ssh key first
i = child.expect([pexpect.TIMEOUT, 'assword', 'yes/no'])
if i == 0:
print('SSH Time OUT!')
sys.exit(3)
if i == 1:
child.sendline(Password)
if i == 2:
child.sendline('yes')
child.expect('assword')
# Expect end of prompt and send command
i = child.expect(['#', '>'])
child.timeout = inputs.clitimeout
if i == 0 or i == 1:
for c in range(len(CLICOMMAND)):
child.sendline(CLICOMMAND[c])
i = child.expect([pexpect.TIMEOUT])
if i == 0:
SessionOutput = child.before + '\n\n'
# Exit connection
if i == 0:
child.sendline('exit')
return SessionOutput
#### Input ARGUMENTS ####
if __name__ == '__main__':
# Input arguments
debug = False
inputs = parse_args()
File = inputs.outputfolder + '/' + inputs.name + '_' + inputs.filename + '.log'
assure_path_exists(inputs.outputfolder)
CommandsToSend = []
if ';' in inputs.clicommand:
for i in range(len(inputs.clicommand.split(';'))):
CommandsToSend.append(inputs.clicommand.split(';'))
else:
CommandsToSend.append(inputs.clicommand)
sshoutput = sshSendCommands(inputs.host, inputs.sshlogin, inputs.sshpassword, CommandsToSend)
RefFile = open(File, 'w')
RefFile.write(str(sshoutput))
RefFile.close()
sys.exit(0)
#!/usr/bin/python
# Date : 29/01/2018
import time
import os
import re
import sys
import copy
import subprocess
import pexpect
#### Functions ####
# Argument parser
sys.exit(3)
@wraps(method)
try:
return f_result
if debug:
raise
sys.exit(3)
return wrapped
# Arguments handler
@tb2unknown
def parse_args():
help='CLI timeout')
return args
@tb2unknown
os.makedirs(dir)
@tb2unknown
# output
SessionOutput = ''
child.timeout = 10
if i == 0:
sys.exit(3)
if i == 1:
if i == 2:
if i == 0:
# Exit connection
if i == 0:
# Input arguments
debug = False
CommandsToSend = []
else:
RefFile.close()
sys.exit(0)
