OXE Avaya PRA trunk down
mdhussainvlr
Post by mdhussainvlr »
I have issue with my qsig trunk where in oxe PRA I getting LOS signal
Also getting incidents
T2 Access 75 end timed out
Also I’m sure the cable between oxe and Avaya is good I tested
What could be the issue for this trunk down ?
dryhouse
Re: OXE Avaya PRA trunk down
Post by dryhouse »
Problem in the Avaya side??
Regards.
mdhussainvlr
After reset the PRA from Avaya The issue will occur again what I have to do for the issue not to be returned
Check clocks, define one as master, guess Avaya should be it. Then your Trunk will sync against it
mdhussainvlr
Hi Cavagnaro thanks for your reply how can I check clock from OXE you are saying about synchronization priority
If that how much value need to set ?
Return to “Boards”
