Installation of OTMS 2.3.1 on HP DL380G9
alexeik
Post by alexeik »
Anyone manged to install OTMS 2.3.1 on a HP DL380G9? release notes says to change the bios mode to legacy, but if i do so there is nothing in the boot menu to boot from...
greets Alex
alexeik
Re: Installation of OTMS 2.3.1 on HP DL380G9
Post by alexeik »
Sooo
i have found the following solution and it worked fine for me:
Note: follow in the right order!
1. BIOS (F9)
a. Set boot mode to legacy (no UEFI)
b. Save and reboot
2. Smart Array Configuration (F10)
a. Tested with RAID1 with 2x 300GB/15k SAS-Disk`s
b. Create Array and reboot
3. Boot from USB Stick/DVD
4. Installation worked
Basically my problem was a HP Server from a distributor and not from ALE. So all was made for UEFI...
and after changing the boot mode to legacy i got a black screen...
after 4 days of testing and googling i found:
If you get a black screen in the KVM / iLO remote video (e.g., on HP ProLiant DL360 G9), then go into ROM Based Setup
 Utility (RBSU) - "Advanced Options" - "Video Options" and change the setting of the embedded video connection from
  "auto" to "always on".
and
What cost us a tons of time was the wrong order of switching to legacy boot and creating the raid:
• FIRST switch to legacy boot
• Only after that, create the raid
so recreating the raid array after switching to legacy boot mode is necessary
greets
tgn
Post by tgn »
thank you very much for sharing, maybe it saves 4 days of my live someday ;)
regards…
Return to “OTMS - OpenTouch Multimedia Services”
