Is there any way to monitor traffic utilization from sdp that bind in the services ?
There're many flooding from several sdp, but I can't find out which sdp
In the services there're 100 sdp binding, so I want to know which sdp that make problems
Mandud
Monitoring SDP Binding Services
Re: Monitoring SDP Binding Services
You can see the ingress and egress forwarded packet statistics for an sdp with the command
The SNMP objects are sdpBindBaseStatsIngFwdOctets and sdpBindBaseStatsEgressForwardedOctets
monitor service id sdp {<sdp-id[:vc-id]>|far-end <ip-address>} [interval <seconds>] [repeat <repeat>] [absolute|rate]
But if you have hundreds of them, probably better to graph them.The SNMP objects are sdpBindBaseStatsIngFwdOctets and sdpBindBaseStatsEgressForwardedOctets
mandud
Hi Mivens,
Thanks your advice, actually I've tried this command but the result error
Based on investigation flooding came from broadcast traffic (broadcast storm) in this services VPLS
is there any way to prevent this in 7750 SR-7 ?
Mandud
A:SR-7# monitor service id 1647 sdp 68:1647 interval
Error: Missing parameter data
A:SR-7# monitor service id 1647 sdp 68:1647 interval 3 repeat 2 ^
Error: Invalid parameter.
- sdp {<sdp-id[:vc-id]>|far-end <ip-address>} [interval <seconds>] [repeat <repeat>] [absolute|rate]
<sdp-id[:vc-id]> : sdp-id - [1..17407]
vc-id - [1..4294967295]
<ip-address> : a.b.c.d - display sdp having this as far-end ip-address
<seconds> : [11..60] - default 11
<repeat> : [1..999] - default 10
<absolute|rate> : keywords - default mode delta
Mandud
The minimum interval is 11:
<seconds> : [11..60]so the command would be
monitor service id 1647 sdp 68:1647 interval 11 repeat 2There are various ways of controlling the flooding of traffic in a VPLS service. There are features such as Auto-Learn MAC Protect and MAC Move that you can configure and that can generate alarms to help you detect and troubleshoot. A service ingress QoS policy can be configured to rate-limit broadcast/unknown MAC traffic etc.
