Factory reset 8039 Deskphone
Go ahead, shoot for the feature requests, and if anyone knows the solution, they will share it with you. If there is a lot of people who request something, I will make a marketing request directly with Alcatel. A good idea would be to create a poll with each request. Alcatel-Lucent is aware of this forum.
shijad007
Post by shijad007 »
How do I factory reset Alcatel 8039 Deskphone? I don't know the operator password. Please help.
mdhussainvlr
Re: Factory reset 8039 Deskphone
Post by mdhussainvlr »
You can try to restart the device in industrial mode can you try this one in 8039 as well
Disconnect/ Power off the set
Reconnect/ Power on the set and push all keys i 1 2 3 simultaneously
Press keys until you get the below mesage
Stuck keys (1) (2) (3)
After that Telnet to phone via putty and enter the command reset flash
After that reset
Configure the PC with IP address 192.168.1.6 and subnet 255.255.255.0
shijad007
Post by shijad007 »
mdhussainvlr wrote: 19 Apr 2018 05:00 Hi,
After that reset
8039 deskphone is not IP phone so this method cannot work as I cannot telnet into the phone.
mdhussainvlr
Are you using OXO if are using OXO you can try to reset the password
May I know Why you need to do factory reset ?
shijad007
Post by shijad007 »
mdhussainvlr wrote: 19 Apr 2018 05:32 Are you using OXO if are using OXO you can try to reset the password
I cannot access the operator mode in the phone as I don't know the password. I guess reset is the only option to access operator mode. I have connected the phone to OXO device. Can i reset the passwords using OXO?
mdhussainvlr
Yes you can do it by OMC
shijad007
Post by shijad007 »
mdhussainvlr wrote: 19 Apr 2018 05:52 Yes you can do it by OMC
I tried using OMC but the reset option is disabled there.
mdhussainvlr
Go to password try to make it to default
shijad007
Post by shijad007 »
mdhussainvlr wrote: 19 Apr 2018 06:14 Go to password try to make it to default
In password option it is showing as default password but I cannot access operator mode with default password.
mdhussainvlr
try help1954
Return to “Feature Request”
