Hi Everyone,
I need to know how can i tell from config or CLI command that VPLS configured in 7750 is Single node or Multi node?
Mike
vpls single node and multi node
Re: vpls single node and multi node
A single-node VPLS doesn't need SDPs (everything's local to the node) so you could check if there any SDPs associated with the VPLS service with "show service id <service-id> sdp".
mike18
I check this VPLS on oneof the noe Node
show service id 17020001 sdp
Services: Service Destination Points
SdpId Type Far End addr Adm Opr I.Lbl E.Lbl
123:4294966611 Bgp* 10.0.16.123 Up Up 261752 262050
128:4294966811 Bgp* 10.0.16.128 Up Up 262114 262117
129:4294966810 Bgp* 10.0.16.129 Up Up 262100 262123
Number of SDPs : 3
so now we can say that this VPLS is Multi node Right?
on same Node when i run below command
show service id 17020001 sap
SAP(Summary), Service 17020001
PortId SvcId Ing. Ing. Egr. Egr. Adm Opr
QoS Fltr QoS Fltr
9/1/8:1700 17020001 1 none 1 none Up Up
9/1/9:1700 17020001 1 none 1 none Up Up
9/1/10:1700 17020001 1 none 1 none Up Up
Number of SAPs : 3
so now we can say that given VPLS 17020001 can be single node and multi node on same Node right?
Mike
Number of SDPs : 3
QoS Fltr QoS Fltr
Number of SAPs : 3
Mike
There are SDPs to three other nodes (10.0.16.123, 10.0.16.128 and 10.0.16.129) so it's multi-node VPLS.
