LAN PC PORT ON IP HANDSETS
selectt
Post by selectt »
HI
I have a client with two internet connections.
1. voice qos bb for SIP traffic on oxo
2. leased line for data traffic
I have installed an alcatel lucent switch 0s6350 and managed two vlans 92 and 100 with various pcs and ip phones.
the client has run out of data sockets so I thought I could utilise the port at the back of the ip sets to connect the pcs to their respective vlans.
I configured as per the system documentation and tagged the port vlan 100 and 92 to the OXO. The land port now works on the 100 network but the phone does not boot up.
if I tag the port to the oxo only with vlan 92 and prog untagged 100 on the same port the phone works but not the lan port ( it connects to vlan 92).
The data switch is working fine as the pcs on their own vlan 100 port are ok its just the issue of using the ip sets for multiple vlans im having issues with.
is this a routing issue on the oxo or the switch ?
I have attached a diagram to explain.
thank you in advance
OXO MULTIPLE VLAN.pdf
mdhussainvlr
Re: LAN PC PORT ON IP HANDSETS
Post by mdhussainvlr »
You can configure as mobile port
In switch :
vlan 92 mobile-tag enable
vlan port mobile 1/1
Vlan 100 port default 1/1
Also need to set Mac rule for IP Phones
vlan 92 Mac range 00:80:9f:00:00:00 00:80:9f:ff:ff:ff
Then connect the IP phone to the configured port & connect the PC
mdhussainvlr
Hi ,
Have you tried ?
selectt
Post by selectt »
all working thanks
Return to “Networking”
