Blocking specific external numbers
AndyK
Post by AndyK »
Hi All
is there a way to block a specific number that is calling a specific DDI on the system ?
I know this can be done if the ACD software is installed via the smart call routing, but is there a way to do it if the ACD software is not installed.
Andy
Re: Blocking specific external numbers
Please search the forum, question answered before.
Read - System doc/ General applications/ Caller /Called filtering.
Return to “MAIN”
