Access the switch using GUI
Enwary
Post by Enwary »
Hi team...
I am new with alcatel switches..I can access my switch using serial port...please could any one help me to access the switch using GUI...thanks...
devnull
Re: Access the switch using GUI
Post by devnull »
setup an IP address for vlan 1
aaa authentification default "local"
and that should be it
Enwary
Post by Enwary »
Many thanks for help..
I configur ip for vlan 1 and authentication as local but I still can't access the switch using GUI.....I can telnet the switch...
Is there any other configuration should be done..
Thanks again..
Enwary
Post by Enwary »
Ok..done..I can access the switch using GUI...
Many many thanks
