OXE CPU switch-over
gilcsr
OXE CPU switch-over
Post by gilcsr »
Hello
just a question...
is it normal that during a cpu switch-over (bascul main xa to xb) all the DECT communications are lost ?
only the IP or Analogic communications are maintained
the redundancy is ok
sorry for my english...
thanks for your answers
oxe R10.1.1-j2.603-29-b-fr-c0
mustafa.ahmad
Re: OXE CPU switch-over
Post by mustafa.ahmad »
No, it is not normal, all the communications must be as they are, only the calls that are being placed or in routing mode get disconnected. Calls already established must remain as in their state before bascul.
Maybe there is bug in the patch.
I think - your DECT sinchronized from CPU. And in this case during switch-over - DECT network reinitalized and all communication lost (the same problem can be with ABC-F calls)
gilcsr
Post by gilcsr »
hi
thanks for your answers :)
so, my ibs or DECT can be synchronized whith only one CPU and that's why it can't be in redondancy ?
nothing to do?
Eliott
Post by Eliott »
You need two DECT8_SYNC boards to have a seamless clock.
Eliott
Post by Eliott »
What are the components?
Can you post a config all and infocs?
Return to “System”
