Alert in log
MaxDevil
Alert in log
Post by MaxDevil »
I have two 6350 configured in stack and in log I have this alerts :
HU AUG 02 23:18:16 2018    CSM-CHASSIS   alert == CSM == cs_csm_rx_hello:1307 - Checksum received from slot 66
THU AUG 02 23:18:16 2018    CSM-CHASSIS   alert == CSM == csCsmHawkRuningChecksumAckSend:3098 - checksum ack sent successfully
THU AUG 02 23:18:16 2018    CSM-CHASSIS   alert [Count.]to slot 66
THU AUG 02 23:28:36 2018    CSM-CHASSIS   alert == CSM == cs_csm_rx_hello:1307 - Checksum received from slot 66
THU AUG 02 23:28:36 2018    CSM-CHASSIS   alert == CSM == csCsmHawkRuningChecksumAckSend:3098 - checksum ack sent successfully
THU AUG 02 23:28:36 2018    CSM-CHASSIS   alert [Count.]to slot 66
THU AUG 02 23:38:56 2018    CSM-CHASSIS   alert == CSM == cs_csm_rx_hello:1307 - Checksum received from slot 66
THU AUG 02 23:38:56 2018    CSM-CHASSIS   alert == CSM == csCsmHawkRuningChecksumAckSend:3098 - checksum ack sent successfully
THU AUG 02 23:38:56 2018    CSM-CHASSIS   alert [Count.]to slot 66
Could you please tell me It's normal or not ?
MaxDevil
Re: Alert in log
probably no issue - checksum successfully every 10 minutes.
But if you are unsure you have to open a ticket at ALE.
Return to “OmniSwitch 6350”
