BFD between VRRP interfaces in a VRF. Possible?
teenoko
Post by teenoko »
I haven't had any luck being able to establish a BFD session between my two VRRP enabled interfaces in a VRF.
The Interfaces are part of a Routed VPLS. Is this possible?
Any help appreciated.
I found Alcatel documentation that outlines VRRP for an IES, but that's' as close to a setting it up in a VRF as possible.
thekotaksampah
Re: BFD between VRRP interfaces in a VRF. Possible?
Post by thekotaksampah »
Sure can. under VRRP configuration in your vprn there is bfd enable capability and pointing interfaces.
            interface "to-x" create
                address <IPAddr>/<PrefixLength>
                vrrp <vrrp_ID>
                    backup <IPAddr>
                    priority <per-value>
                    bfd-enable 100 interface "to-x" dst-ip <IPAddr> #peer node
                exit
            exit
Technical Blog: ngoprek.achyarnurandi.id
bmccloskey
Post by bmccloskey »
Does bfd need to be configured in the L3 interface as well as VRRP? Does there need to be any type of bfd-template and bfd-enable added to the vpls mesh or spokes?
thekotaksampah
As per check, there is no configuration at the moment. Since you put L3 technologies to L2 aware technologies :)
Return to “7750 SR”
