OXE Upgrade 11.2 to R12.2
junoooni
I am planning to upgrade one customer from OXE R11.2 to R12.2... It is a common HW based system with duplicated CS-2... I was referring to TC2473 but it confused me a bit with:
Page 17: Coming from ANY version <12.0 the cpu MUST be reformatted
Page 28: PC Installer is no more supported. Installing old versions will be not available as well as boards firmware reload.
Page 39: Do not proceed by switchover for 2 different releases: a complete stop of the telephony is required. It is not recommended also to proceed by “bascul” when installing a static patch though there is no clear rule established. During that time (patch n & patch n+1 on main & stand-by), the command “twin” may return the status “KO” for the “memloader” check.
What i need to know is:
1- What backup options shall I select before starting upgrade?
2- Can I upgrade Standby Server first and then do a restore on it?
3- Can I do a bascul on upgraded standby so that new release can takeover?
4- Once upgraded server takeover, GD will restart automatically or do I need to manually restart GD and GA to enable download of new binaries?
5- All the IP Phones will be upgraded automatically or do I need to reset (most of phones are 8018)
6- How long with be downtime?
Re: OXE Upgrade 11.2 to R12.2
this mens there is no possibility to install on 2nd partitions.junoooni wrote: Page 17: Coming from ANY version <12.0 the cpu MUST be reformatted
this means you have to use the software orchestration tool when doing the cpu installation on the official way (but pc installer 5.4 will work too at the moment)junoooni wrote: Page 28: PC Installer is no more supported. Installing old versions will be not available as well as boards firmware reload.
this means you have to plan a downtime of the phone system.junoooni wrote: Page 39: Do not proceed by switchover for 2 different releases: a complete stop of the telephony is required. It is not recommended also to proceed by “bascul” when installing a static patch though there is no clear rule established. During that time (patch n & patch n+1 on main & stand-by), the command “twin” may return the status “KO” for the “memloader” check.
just backup all that you can backup in swinst menu.junoooni wrote: 1- What backup options shall I select before starting upgrade?
also think about rebuilding the database index and check for database errors.
yes. you can install there (but think about the harddisk age).junoooni wrote: 2- Can I upgrade Standby Server first and then do a restore on it?
no (as written on page 39)junoooni wrote: 3- Can I do a bascul on upgraded standby so that new release can takeover?
yes, it will download new binaries and will reboot more than once to flash it.junoooni wrote: 4- Once upgraded server takeover, GD will restart automatically or do I need to manually restart GD and GA to enable download of new binaries?
yes. but may be delayed or switched off depending on phone feat. cos or phones tcp/ip parameters.junoooni wrote: 5- All the IP Phones will be upgraded automatically or do I need to reset (most of phones are 8018)
it depends on severeal factors... one, two or three hours... or more if you running in problems... better try it on a test system before the real upgrade if you have a problem with a longer downtime.junoooni wrote: 6- How long with be downtime?
regards...
Make sure you’re server hardware can support the new Version I had to order new servers for one of my nodes because the bios couldn’t be upgraded to the latest release that 12.2 needs to be on.
Make sure you also rebuild the DB with the fichges command before you back it up and install on the Rel 12.x system
junoooni
Thanks alot for all the valuable feedback...
I have CS-2 and it was installed only a year back so HDD age and physical server HW shouldnt be an issue...
My only concern is to convince customer for a longer downtime...
If long time is a concern what our OXE guys did was to take a small caninet and plug critical lines. Public, and few admin stations or Ip. Idea was to allow external critical communication. Later you just unplug and leave with customers one
junoooni
I am planning as below:
1- disconnect standby from network and upgrade and restore backup.
2- Once standby is online, disconnect current active and connect new upgraded CS to network.
3- Reboot GD and ensure all services are back online
4- Upgrade the disconnected CS and restore backup.
5- Connect it back to network
6- Check twin and ensure everything fine
How does this sound? Any drawbacks?
junoooni
junoooni
Update:
I had downloaded R12.2 and installed PC Installer 5.4?available in iso image.
Did grubboot ether command, CS2 rebooted and it is getting stuck at acquiring IP address and after sometime it fails to get IP address and reboots.
On my laptop, i have disabled all NIC’s and only ethernet active which is connected to CS2 using straight cable (no IP address assigned to latop)
Firewall is off, defender is off, antivirus stopped. Still no luck..
Installed SOT using VMware player and Virtual Box, both starts SOT VM successfully and show message SOT is ready to accept web client connection on https://10.1.1.55 (default IP) i can ping this IP but web browser does not open, tried with chrome, firefox, edge, IE nothing helped.
Any ideas please.. M sure many of you would have done this or similar upgrades.
