Hi ,
I have configured Avaya as SIP device with internal SIP trunk with OXE and below is the call scenario
Avaya -A calls to Avaya-B then Avaya-B doing Blind transfer to Noe
Transfer from Avaya-B is success and showing transfer completed successfully
But Noe-A calls to Avaya-A and Avaya-A transfers call to either Noe-B or Avaya-B
From Avaya-A call transfer is happening. But the display in Avaya-A shows call on hold until you reset the device and the line is not releasing
Any idea ? is it possible to check from the SIP traces
Hi! - I moved the server over the week end to handle the daily incoming connections (about 200K/day) but it looks like I aimed too low for the resources. I'm going to have to move this server (hopefully for the last time) this week. I'm sorry for the interruption.
Oxe to Avaya transfer issue
mdhussainvlr
- cavagnaro
Re: Oxe to Avaya transfer issue
Logs...please! Logs!
Your configuration...something please
- giovanni.attolini
Low bat on crystal ball... kkkkk
Giovanni A. Attolini
- cavagnaro
XD its magical WiFi signal is not reaching his OXE [emoji23]
