I have a question about that error which happed after I configure TAPI premium server for Recall IP from Jusan. In TAPI server I set the main IP address of duplacited OXE. And atfer CSTA connection with server it start to write these errors:
02/10/18 07:43:47 000001M|---/--/-/---|=0:2663=IPC Chorus err: appli ACCOUNTING oper 6 err -7
02/10/18 07:44:47 000001M|---/--/-/---|=0:2663=IPC Chorus err: appli ACCOUNTING oper 6 err -7
02/10/18 07:45:49 000001M|---/--/-/---|=0:2663=IPC Chorus err: appli ACCOUNTING oper 6 err -7
02/10/18 07:46:18 000001M|---/--/-/---|=0:2663x002=IPC Chorus err: appli ACCOUNTING oper 6 err -7
02/10/18 07:47:01 000001M|---/--/-/---|=2:2679=CMIS err rcp EFD on stand-by CPU: appli CMISE err 0
02/10/18 07:47:09 000001M|---/--/-/---|=0:2663=IPC Chorus err: appli ACCOUNTING oper 6 err -7
02/10/18 07:47:38 000001M|---/--/-/---|=0:2663x002=IPC Chorus err: appli ACCOUNTING oper 6 err -7
02/10/18 07:49:35 000001M|---/--/-/---|=0:2663=IPC Chorus err: appli ACCOUNTING oper 6 err -7
02/10/18 07:50:18 000001M|---/--/-/---|=0:2663=IPC Chorus err: appli ACCOUNTING oper 6 err -7
02/10/18 07:51:51 000001M|---/--/-/---|=2:2679=CMIS err rcp EFD on stand-by CPU: appli CMISE err 4
02/10/18 07:51:52 000001M|---/--/-/---|=0:2663=IPC Chorus err: appli ACCOUNTING oper 6 err -7
02/10/18 07:54:02 000001M|---/--/-/---|=0:2663=IPC Chorus err: appli ACCOUNTING oper 6 err -7
02/10/18 07:55:13 000001M|---/--/-/---|=0:2663=IPC Chorus err: appli ACCOUNTING oper 6 err -7
02/10/18 07:56:41 000001M|---/--/-/---|=2:2679=CMIS err rcp EFD on stand-by CPU: appli CMISE err 0
02/10/18 07:58:11 000001M|---/--/-/---|=0:2663=IPC Chorus err: appli ACCOUNTING oper 6 err -7Thank you !
