Question about exporting / deleting / importing a trunk group
melozurdo
Post by melozurdo »
Hi guys,
I have question about exporting / deleting / importing a trunk group configuration from Omnivista 8770.
I need to convert existing trunk group type COMB/MIXED to T1 CSS type. I don´t know what would be the right procedure to do this but need to check with you if I am doing fine:
1. I ´ve been informed that we have to mirror existing T1 CSS trunk group so...export existing T1 CSS trunk group type in txt document.
2. Modify just only Node Name and Trunk group id in the txt document. I don´t know about the rest of parameters but physical location (card) in the PBX is the same so I think it´s not needed to change but let me know.
3. Delete existing trunk group type COMB/MIXED
4. Import new T1 CSS trunk group (the one from step 2).
Another concern I have is...what happens with all the dependencies of the trunk...for instance...existing ARS Router Lists. They will still working after the change? I even wondering if we have to revert back the change, these ARS will still working as expected.
Is there also another thing that should worry about?
As you see, there some questions about this change. Thanks for your help.
Nacho
Return to “Trunk Groups”
