One way audio in outgoing call
- mustafa.ahmad
We have STC SIP connected to an OXE.
Incoming is not at all working, gives a wrong number prompt.
Outgoing is one way audio. Can anyone guide for the resolution.
Thanks in advance
Thanks in advance
- mustafa.ahmad
Re: One way audio in outgoing call
Also, if anyone can let me know where to find the IP compression type parameter that was in the Trunk group parameters in old releases.
because the STC SIP provider is saying that codec from there side is G711. In OXE , where do we exactly change the codec for trunk .
Please search the forum. Issue discussed several times. RTP being blocked
Also read SIP documentation from OXE. It has all explained there
- mustafa.ahmad
The SIP provider has shared the following capture
INVITE sip:0539061760@10.200.0.7;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.141.218.38:5060;branch=z9hG4bKsbcthLNQBVp6zHLLHaAxLLVI0xnVl0IVH6aaAn0ZT24453
Record-Route: <sip:10.141.218.38:5060;transport=udp;lr>
Call-ID: sbcthLNQxVpazpBILlxp6clnnlVLn6VZnnp6cZAc@BI.AV.H.BB
From: "IT DIRECTOR"<sip:8352414@10.200.0.7;user=phone>;tag=sbc0807sbcthLNQBzAlxZaBpxaVBnAa0ZZBBHBxaapnacIB
To: <sip:0539061760@10.200.0.7;user=phone>
CSeq: 572521476 INVITE
Allow: INVITE,ACK,CANCEL,BYE,PRACK,NOTIFY,SUBSCRIBE,OPTIONS,UPDATE
Supported: timer,path,100rel
User-Agent: OmniPCX Enterprise R12.0 m1.403.12.g
Session-Expires: 1800;refresher=uac
Min-SE: 900
P-Asserted-Identity: "IT DIRECTOR"<sip:8352414@10.189.10.130;user=phone>
Contact: <sip:8352414@10.141.218.38:5060>
Max-Forwards: 70
Content-Length: 342
Content-Type: application/sdp
v=0
o=- 1538662361 1538662361 IN IP4 10.205.20.18
s=SBC call
c=IN IP4 10.205.20.18
t=0 0
m=audio 10804 RTP/AVP 9 8 18 97
a=sendrecv
a=rtpmap:9 G722/8000 ---------------------------------------- Remove
a=ptime:20
a=maxptime:30
a=rtpmap:8 PCMA/8000
a=ptime:20 ---------------------------------------- Remove
a=maxptime:30 ---------------------------------------- Remove
a=rtpmap:18 G729/8000 ---------------------------------------- Remove
a=fmtp:18 annexb=no
a=ptime:20---------------------------------------- Remove
a=maxptime:40---------------------------------------- Remove
a=rtpmap:97 telephone-event/8000
They Have asked to remove the highlighted portion
Min-SE: 900
Max-Forwards: 70
Content-Length: 342
v=0
s=SBC call
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
- mustafa.ahmad
Also they have told OXE is giving 403 forbidden response.
[No. ] 54
[TimeStamp ] 2018-10-04 17:13:34
[Direction ] SEND
[Msg Name ] OPTIONS
[Module No ] 190
[Local Address ] 10.200.0.7:5079
[Remote Address] 10.141.218.38:5060
[Hex Msg ] 4F 50 54 49 4F 4E 53 20 73 69 70 3A 31 30 2E 31 34 31 2E 32 ...
OPTIONS sip:10.141.218.38:5060 SIP/2.0
Via: SIP/2.0/UDP 10.200.0.7:5079;branch=z9hG4bKtu2ts4pa7abuduubppuhuakh2
Call-ID: kt4kfdbcskapth7477oocdckfb4ufsc2@SoftX3000
To: <sip:10.141.218.38>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
[No. ] 55
[Direction ] RECV
[Msg Name ] 403
[Module No ] 190
[Hex Msg ] 53 49 50 2F 32 2E 30 20 34 30 33 20 46 6F 72 62 69 64 64 65 ...
SIP/2.0 403 Forbidden
To: <sip:10.141.218.38>;tag=sbc0806sbcthLNQL6IlZBzIlBnza0ac0zp0IpVLpH6aHZaL
CSeq: 1 OPTIONS
Allow: INVITE,ACK,CANCEL,BYE,PRACK,NOTIFY,REFER,SUBSCRIBE,OPTIONS,UPDATE
Content-Length: 0
[No. ] 56
[TimeStamp ] 2018-10-04 17:13:53
[Direction ] SEND
[Msg Name ] OPTIONS
[Module No ] 196
[Local Address ] 10.200.0.7:5084
Via: SIP/2.0/UDP 10.200.0.7:5084;branch=z9hG4bKdth2afh2o7ftdhu4et7f4d7c4
Call-ID: cadocoa2hfboke47scckh7tuhcfhohes@SoftX3000
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
[No. ] 57
[TimeStamp ] 2018-10-04 17:13:54
[Direction ] RECV
[Msg Name ] 403
[Module No ] 196
To: <sip:10.141.218.38>;tag=sbc0804sbcthLNQpc6zHn0xccVzzHAL0nBc0BH0IlcZplZa
CSeq: 1 OPTIONS
Content-Length: 0
[No. ] 54
[Direction ] SEND
[Msg Name ] OPTIONS
[Module No ] 190
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
[No. ] 55
[Direction ] RECV
[Msg Name ] 403
[Module No ] 190
CSeq: 1 OPTIONS
Content-Length: 0
[No. ] 56
[Direction ] SEND
[Msg Name ] OPTIONS
[Module No ] 196
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
[No. ] 57
[Direction ] RECV
[Msg Name ] 403
[Module No ] 196
CSeq: 1 OPTIONS
Content-Length: 0
fery_s
since release 11.2 the trunk codec is change from "SIP EXT Gateway" menu with option "Type of codec negotiation".mustafa.ahmad wrote: ↑04 Oct 2018 09:17 Also, if anyone can let me know where to find the IP compression type parameter that was in the Trunk group parameters in old releases.
fery_s
mustafa.ahmad wrote: ↑05 Oct 2018 01:19 Also they have told OXE is giving 403 forbidden response.
[No. ] 54
[Direction ] SEND
[Msg Name ] OPTIONS
[Module No ] 190
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
[No. ] 55
[Direction ] RECV
[Msg Name ] 403
[Module No ] 190
CSeq: 1 OPTIONS
Content-Length: 0
[No. ] 56
[Direction ] SEND
[Msg Name ] OPTIONS
[Module No ] 196
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
[No. ] 57
[Direction ] RECV
[Msg Name ] 403
[Module No ] 196
CSeq: 1 OPTIONS
Content-Length: 0
403 forbidden usually occurs when authentication has problem, if you set the correct user and password, then add the remote IP address in the "Trusted IP Addresses".
- mustafa.ahmad
Hi Fery,
After adding the SIP provider IP in Trusted IP address , the incoming calls are working.
But the issue for both incoming and outgoing is same , one way audio..
fery_s
check the RTP port range in your firewall , maybe firewall blocked them, also check the ip phone's ip range has route to and from provider ip range.mustafa.ahmad wrote: ↑07 Oct 2018 03:05 Hi Fery,
But the issue for both incoming and outgoing is same , one way audio..![]()
