Command to install multiple DECT at the time
Everything about the PWT, IBS, RBS, DECT..
snoobz
Post by snoobz »
I would like to know the command on OXE system to install multiple DECT at the same time. Because, if I use the command 'dectinston' I can only install one DECT at the time....
Please, don't refer me to check out the Alcatel documentations because I didn't find anything in there!!
Also, before posting this thread I searched my question on Alcatel Unleashed and found only one thread which has no answers on it.
Link to that thread: http://www.alcatelunleashed.com/viewtop ... ct#p100515
In case you guys are wondering, I'm using the version R12.1
Would love if anyone could give me the command to do so!
Re: Command to install multiple DECT at the time
When you use "dectinston" - you know (can manage) - this set will have this number.
If (teoretically) - you start multiple registration (many people start registration prosedure on sets) - and after you will try to find which sets have which number.
Return to “Wireless configuration and sets”
