Rate on queue in Sap-egress
raymondsayo
Post by raymondsayo »
Hi guys,
I was wondering if anyone has seen this issue before where when I put a rate on a queue in a sap-egress qos policy, I only get 'half" of the rate via running bandwidth test? So say if I set the rate to 100M, I get 50M - 90M/45M 60M/30 and so on?
queue 1
rate 100000
paramount
Re: Rate on queue in Sap-egress
Post by paramount »
Hey Raymond,
May need to see a little more of your config. I think I have seen similar when it's assigned to a sap on a lag, where it autmatically splits the bandwidth between the two ports if a two port lag.
Can;t remember if this was default, or an option, but have def seen it.
Paramount
raymondsayo
Hey Paramount,
Thanks for the reply.
So basically a sap-egress policy applied on a pw-port that is bound to a lag port ( lag-1) - so you could be on the money.
What checks do I need to carry out pls to rule this out?
Thanks again,
Raymond
raymondsayo
Also, what do I need to check and potentially resolve the issue?
Is is worthwhile shutting down one port on the LAG to force traffic to run on single port?
Thanks!
Return to “7750 SR”
