we used LLDP-MED and vlan port mobility to daisychain a computer behind an alcatel lucent telephone, which is directly connected to a switchport.
we want the PC to be able to communicate with VLAN 2320, the telephone with VLAN 2362.
This works perfectly if we TAG VLAN 2362 to the port, and set VLAN2320 as untagged.
We're not able to replicate this old configration to unp profiles, somehow.
Following is the unp and lldp config:
lldp network-policy 1 application voice vlan 2362 l2-priority 5 dscp 46 lldp nearest-bridge chassis tlv med network-policy enable lldp chassis med network-policy 1
unp profile "vlan2362" unp profile "vlan-profile" mobile-tag unp profile "vlan2362" map vlan 2362 unp port-template voice-t direction both classification trust-tag admin-state enable unp port 1/1/4-48 port-type bridge unp port 1/1/4-48 port-template voice-t unp classification ip-address 172.23.20.0 mask 255.255.255.0 vlan-tag 2320 profile1 "vlan2362" unp classification lldp med-endpoint ip-phone profile1 "vlan2362"
vlans (this looks good !):
-> show vlan members port 1/1/16 vlan type status --------+-----------+--------------- 2320 default forwarding 2362 unpQtag forwarding
which produces the following "show unp user" output:
Port Username Mac address IP Vlan Profile Type Status -------+--------------------+-----------------+---------------+----+--------------------------------+------------+----------- 1/1/16 00:80:9f:xx:xx:xx 00:80:9f:xx:xx:xx - 2320 - Bridge Block 1/1/16 00:80:9f:xx:xx:xx 00:80:9f:xx:xx:xx 172.23.62.16 2362 - Bridge Active 1/1/16 10:65:30:xx:xx:xx 10:65:30:xx:xx:xx 172.23.20.10 2320 - Bridge Block
I tried many different configurations, but this one is the most minimalistic and "clean", where every address gets displayed correctly,
but my computer which is connected with the ip-adress 172.23.20.10 is not able to ping anything, since the status is blocked.
Would love some help here! Thank you
