We daisy-chained a PC behind an integrated switch on an alcatel telephone. In AOS you can't configure port-mobility as easy as in older releases.
the phone gets its voip vlan and connects to the OXO. but the PC is not able to ping or connect to the network (Status blocked).
Why is the configured default - VLAN blocked in this scenario, and how can we allow it?
just a short question. I have following output:
-> show unp user
User
Port Username Mac address IP Vlan Profile Type Status
1/1/7 00:80:9f:d4:ac:da 00:80:9f:d4:ac:da 172.23.62.18 2362 - Bridge Active
1/1/7 10:65:30:c5:5f:34 10:65:30:c5:5f:34 172.23.2.100 2302 - Bridge Block
this is my unp config:
unp profile "data" unp profile "voip" mobile-tag unp profile "voip" map vlan 2362 unp port-template data-c direction both default-profile "voip" classification trust-tag admin-state enable unp port 1/1/7 port-type bridge unp port 1/1/7 port-template data-c unp classification vlan-tag 2302:2363 profile1 "data" unp classification lldp med-endpoint ip-phone profile1 "voip"
Cheers,
Pascal
