figuring out which parameter was incorrect in an PBX management operation
ssteiner
Post by ssteiner »
I'm try to rollback a subscriber deletion. So, I extracted the PbxObject, then deleted it, then try to send all its attributes (it's 120) again. Naturally that is turned down. The response only tells me something is wrong with my input, not what:
	"httpStatus": "BAD_REQUEST",
	"code": 1006,
	"helpMessage": "Request parameters are not correct. Please fix the problem and resend the request.",
	"type": "BAD_PARAMETER",
	"innerMessage": "Parsing error",
	"canRetry": true
And is there a way to automate this.. so I can take a set of PbxAttributes, and somehow figure out which ones I may not set upon add. So far it's been trial and error for simpler objects, but having 120 properties, trial and error isn't gonna work here.
The request
	"attributes": [{
		"name": "ACD_Group_Directory_Number",
		"value": [""]
		"name": "ACD_Type",
		"value": ["No_ACD"]
		"name": "Add_On_Module_1",
		"value": ["No_Extension"]
		"name": "Add_On_Module_2",
		"name": "Add_On_Module_3",
		"name": "AdvancedConfiguration",
		"value": ["false"]
		"name": "Annu_First_Name",
		"value": [""]
		"name": "Annu_Name",
		"value": ["test"]
		"name": "Associated_Dect",
		"value": [""]
		"name": "Associated_RSI",
		"value": [""]
		"name": "Associated_Station_Directory_Number",
		"value": ["9563"]
		"name": "Associated_Videophone",
		"value": ["false"]
		"name": "Attached_MultiTandem",
		"value": []
		"name": "CTQ_RA_Type",
		"value": ["CTQ_NOK_TO_OK"]
		"name": "Call_Announce_Group",
		"value": ["-1"]
		"name": "Call_By_Name_Mini_Messaging_Right",
		"value": ["Yes"]
		"name": "Call_Conference_Group",
		"value": ["-1"]
		"name": "Call_Priority",
		"value": ["0"]
		"name": "Caller_Category",
		"value": ["4"]
		"name": "ClickAndPh",
		"value": ["A4980_XmlApi"]
		"name": "Connection_Category_Id",
		"value": ["0"]
		"name": "Cost_Center_Id",
		"value": ["255"]
		"name": "Cost_Center_Name",
		"value": [""]
		"name": "DEV_Routing_Flag",
		"value": ["false"]
		"name": "Destination_Node",
		"value": ["43"]
		"name": "Dialled_Number_Masked_In_Ticket",
		"value": ["No"]
		"name": "Directory_Number",
		"value": ["9563"]
		"name": "Display_Name",
		"value": ["test"]
		"name": "Domain_Identifier",
		"value": ["0"]
		"name": "Emulation_Paging_Right",
		"value": ["No"]
		"name": "Entity_Number",
		"value": ["1"]
		"name": "Equipment_Address_Board",
		"value": ["255"]
		"name": "Equipment_Address_Rack",
		"value": ["255"]
		"name": "Equipment_Address_Terminal",
		"value": ["255"]
		"name": "Explicit_Prio.Priority_Level",
		"value": ["0"]
		"name": "Explicit_Prio.Priority_Mode",
		"value": ["0"]
		"name": "External_Forwarding_Category_Id",
		"value": ["255"]
		"name": "Facility_Category_Id",
		"value": ["11"]
		"name": "Function",
		"value": ["Administrative"]
		"name": "GFU_Incoming_Access",
		"value": ["false"]
		"name": "GFU_List_Number",
		"value": ["-1"]
		"name": "GFU_Outgoing_Access",
		"value": ["false"]
		"name": "GFU_Preferential",
		"value": ["-1"]
		"name": "Implicit_Prio.Priority_Level",
		"value": ["0"]
		"name": "Implicit_Prio.Priority_Mode",
		"value": ["0"]
		"name": "Internal_Keyboard",
		"value": ["German"]
		"name": "Ith_Service_Type",
		"value": ["No_Valide"]
		"name": "Key_Profile",
		"value": ["None"]
		"name": "Language_Id",
		"value": ["1"]
		"name": "Metering_Category",
		"value": ["Justified"]
		"name": "Msg_Class_nb",
		"value": ["7"]
		"name": "Multi_Line_Facility.Delay_Overflow_For_Waiting_Call",
		"value": ["false"]
		"name": "Multi_Line_Facility.Immediate_Overflow_For_Waiting_Call",
		"value": ["false"]
		"name": "Multi_Line_Facility.MLA_Automatic_Outgoing_Seize",
		"value": ["false"]
		"name": "Multi_Line_Facility.Multine_Automatic_Incoming_Seize",
		"value": ["true"]
		"name": "Multi_Line_Facility.Multine_Automatic_Outgoing_Seize",
		"value": ["true"]
		"name": "Multi_Line_Facility.Multine_Selective_Filtering",
		"value": ["false"]
		"name": "Multi_Line_Facility.ake_Supervision_Off_Hook",
		"value": ["false"]
		"name": "Multi_Line_Station",
		"value": ["No"]
		"name": "Nb_Error_CodAffaire",
		"value": ["0"]
		"name": "Nb_Error_CodSecret",
		"value": ["0"]
		"name": "Nomadic_dec",
		"value": ["false"]
		"name": "Number_Of_Users",
		"value": ["1"]
		"name": "Occupation_Type",
		"value": ["Normal"]
		"name": "Ope_Cca",
		"value": ["false"]
		"name": "PCBT_Associated",
		"value": ["No"]
		"name": "PIN.Pin_Group",
		"value": ["1"]
		"name": "PIN.Pin_Number",
		"value": [""]
		"name": "PIN.Pin_Type_Of_Control",
		"value": ["PIN_Category"]
		"name": "PIN.With_Secret_Code",
		"value": ["true"]
		"name": "Paging_Beeper_Directory_Number",
		"value": [""]
		"name": "Paging_Trunk_Group_Number",
		"value": ["255"]
		"name": "Phone_Book_First_Name",
		"value": [""]
		"name": "Phone_Book_Name",
		"value": ["test"]
		"name": "Pickup_Group_Name",
		"value": [""]
		"name": "Pin_Group_Control",
		"value": ["No_Group_Access"]
		"name": "Primary_Line_Prio",
		"value": ["No"]
		"name": "Prio_Presentation",
		"value": ["No"]
		"name": "Public_Network_Category_Id",
		"value": ["2"]
		"name": "Reserved_Time_Slot",
		"value": ["false"]
		"name": "Right_Profile_Name",
		"value": [""]
		"name": "Robinet_Category",
		"value": ["0"]
		"name": "Robinet_Right",
		"value": ["0"]
		"name": "Routing_Number",
		"value": ["0"]
		"name": "S0_Presence",
		"value": ["false"]
		"name": "Secondary_Line_Prio",
		"value": ["No"]
		"name": "Secret_Code",
		"value": ["0000"]
		"name": "Secret_Code_Access_For_SUU",
		"value": ["No"]
		"name": "Secretary_Directory_Number",
		"value": ["9563"]
		"name": "Set_Role",
		"value": ["Default"]
		"name": "Stap",
		"value": ["off_hook"]
		"name": "Station_Group_Directory_Number",
		"value": [""]
		"name": "Station_Type",
		"value": ["NOE_B"]
		"name": "Supplementary_Service_Right.Display_Ext_Calling",
		"value": ["true"]
		"name": "Supplementary_Service_Right.External",
		"value": ["true"]
		"name": "Supplementary_Service_Right.Internal",
		"value": ["false"]
		"name": "TAPIPremiumServer",
		"value": ["No"]
		"name": "Tandem.Partial_Occ",
		"value": ["false"]
		"name": "Tandem.Ringing_In_Partial_Occ",
		"value": ["Long_Ring"]
		"name": "Tandem.Specific_Supervision",
		"value": ["false"]
		"name": "Tandem.Tandem_Directory_Number",
		"value": [""]
		"name": "Tandem.Tandem_Principal",
		"value": ["false"]
		"name": "Tele_Marketing_Actor",
		"value": ["false"]
		"name": "Teleservice",
		"value": ["Phone"]
		"name": "Teleservice_Incident",
		"value": ["No"]
		"name": "Text_MSG_Number",
		"value": ["8"]
		"name": "Transparency_VSI",
		"value": ["false"]
		"name": "Type_of_Keyboard",
		"value": ["EUROPEAN_KB"]
		"name": "URL_Domain",
		"value": [""]
		"name": "URL_UserName",
		"value": [""]
		"name": "UTF8_Phone_Book_First_Name",
		"value": [""]
		"name": "UTF8_Phone_Book_Name",
		"value": [""]
		"name": "Urgent_Call",
		"value": ["No"]
		"name": "Use_Private_Calling_Number",
		"value": ["false"]
		"name": "VIP",
		"value": ["false"]
		"name": "Valid_For_Call_By_Name",
		"value": ["Yes"]
		"name": "Voice_Mail_Directory_Number",
		"value": [""]
		"name": "Voice_Mail_Type",
		"value": ["No_Mevo"]
		"name": "Z_Subdevice",
		"value": ["false"]
		"name": "Z_ivr",
		"value": ["false"]
yblanchard
Re: figuring out which parameter was incorrect in an PBX management operation
Post by yblanchard »
The attributes that cannot be set in mgr at Subscriber creation must not be used with O2G.
I don't see any easy solution to automate object re-creation from attributes built from a previous get.
In particular for the Subscriber object which is the most complex object, some attributes (for example Tandem_xxx) cannot be set on object creation,
but only at object modification.
So, to re-create a Subscriber, the application must have the control of the whole parameters, like for a first object creation.
ssteiner
Post by ssteiner »
Isn't there a list of attributes that you can't set on create?
I create my devices based on a template (create user by profile), but unfortunately OXE does not "remember" which profile was used to create a user, hence you're not able to re-create the device based on whatever template was used for first creation.
yblanchard
Following is the attribute list that CAN be used on create: the other are not permitted:
ACD_Type
Add_On_Module_2
Add_On_Module_3
Annu_First_Name
Annu_Name
Associated_RSI
CTQ_RA_Type
Call_Announce_Group
Call_Priority
Caller_Category
ClickAndPh
Cost_Center_Id
Cost_Center_Name
Directory_Number
Display_Name
Domain_Identifier
Entity_Number
Function
GFU_Incoming_Access
GFU_List_Number
GFU_Outgoing_Access
GFU_Preferential
Ith_Service_Type
Key_Profile
Language_Id
Metering_Category
Msg_Class_nb
Nb_Error_CodAffaire
Nb_Error_CodSecret
Number_Of_Users
Occupation_Type
Ope_Cca
PCBT_Associated
Phone_Book_Name
Pickup_Group_Name
Pin_Group_Control
Primary_Line_Prio
Prio_Presentation
Profile_Type
Reserved_Time_Slot
Right_Profile_Name
Robinet_Category
Robinet_Right
Routing_Number
Secondary_Line_Prio
Secret_Code
Set_Role
Station_Type
TAPIPremiumServer
Teleservice
Transparency_VSI
Type_of_Keyboard
URL_Domain
URL_UserName
UTF8_Comment1
UTF8_Comment2
UTF8_Comment3
UTF8_Comment4
Urgent_Call
VIP
Z_ivr"
ssteiner
Post by ssteiner »
Did you get that from the schema? there's a way to get the schema.. so I could process that automatically if the schema info is enough (which would be very helpful of course)
yblanchard
Unfortunately, the model doesn't give this information: I've needed to remove from the initial list all the attrributes which are not part of the Subscriber mgr creation (+ the PIN_*** one which with it doesn't work).
ssteiner
Post by ssteiner »
Any chance for a feature request then? The ability to roll back any operation is something crucial in a provisioning API
Return to “O2G”
