AOS Release Versions vs. Device compatibility matrix
fkromer
Post by fkromer »
It is not obvious to me what AOS Release versions are compatible with which Device Series. Different AOS CLI Release Guides state in the beginning something about the device series supported. However single commands must not be supported for all Device Series (statement about "platforms supported" in the corresponding command sections). Is there some compatibility matrix about AOS release versions and device series supported? As it would probably be too fine granular: Is there a compatibility matrix about AOS release versions, supported devices on a per command basis?
Re: AOS Release Versions vs. Device compatibility matrix
Overwiew of all actual models
OS6350, OS6450 –> AOS Rel. 6
  • Based on VxWorks
    Actual is AOS 6.7.2.R04
OS6900–> AOS Rel. 7 –> AOS Rel. 8
  • Based on Linux
    Actual is AOS 8.5R2
OS6465, OS6560, OS6860(E), OS6865, OS9900 –> AOS Rel. 8
  • Based on Linux
    Actual is AOS 8.5R2
last release of all models
Rel. 6
  • OS6850E* 6.4.6.R01
    OS6855* 6.4.6.R01
    OS9000E* 6.4.6.R01
    OS6250* 6.7.1.R04
    OS6450 6.7.2.R04
    OS6350 6.7.2.R04
Rel. 8
  • OS6900-X/T/Q 8.5.R2
    OS6900-V/C 8.5.R2
    OS10k* 8.3.1.R01
    OS6860/6860E 8.5.R2
    OS6560 8.5.R2
    OS6865 8.5.R2
    OS9900 8.4.1.R03
    OS6465 8.5.R2
* end of sales
best regards
fkromer
Post by fkromer »
HI Silvio,
thx a lot for the info.
Is this info maintained on a public website as well? Would be great not to have to ask for updates over time.
I assume you are speaking german ..... so you can look here http://dokuwiki.alu4u.com/doku.php
This isn't a official page too...
For all your other questions you need access to an official alcatel business partner.
Return to “Misc”
