Synchronization Issue
gundam
Post by gundam »
I am getting an error message when running a full sync:
Error while synchronizing MIB
Any idea why?
RuSt
Post by RuSt »
Try to read the logfiles under \4760\log\
And the name ar somthing like SyncPBx.... I don't remember.
Check if you can do a ftp-connection to the 4400, mib-sync uses ftp.
Check the ftp username/password in Directory->Technical.
Also check if the subnet and pbx have the correct networknumber and nodenumber.
I would guess that it's one of these things. Ftp problems or wrong node/networknumber.
Good luck!
la_toupie
Post by la_toupie »
Check the parameter 47xx in your PBX :wink:
Stupid 4760, huh ..?
I have an error too:
Some PCX systems have not been not fully loaded
If anyone has the answer.. :-)
Error message: The system is not fully not loaded
Ok, I just received the solution from the NOC...
If your network is 0
If your subnetwork is 0
Then the node number has to be 00# (with # for the real node number).
Thanks to the VZ NOC !
Just learned something else.
If you have 2 4760, this might be an issue for the synchronisation (for example, if you do a COMPLETE one, it might fail). I worked all night on a case, when we finally turned off the 2nd one and it worked... Good to know !
RuSt
Re: Error message: The system is not fully not loaded
Post by RuSt »
frank wrote:Ok, I just received the solution from the NOC...
This is only true for releases older than 3.0.
For 3.0 and newer you have to use just #, NOT 00#. :)
Why do it the easy way, when you can do it the french way :)
Return to “OmniVista 4760”
