I setup um link H323 between "OXE" and Cisco and I have 2 problems,
1. calls coming from the cisco fall down when you answer.
2. outgoing OXE calls drop after 30s
the board is GD3 and the codec is G711 ou G729.
OXE release 12 with cisco Gateway 2801
ACSE R10.0
Re: OXE release 12 with cisco Gateway 2801
Check with "t3" trace - what happen.
the T3 trace:
| (146293:000220:04237) Concatenated-Physical-Event :
| long: 84 desti: 0 source: 0 cryst: 1 cpl: 0 us: 0 term: 0 type a5
| tei: 0 >>>> message received : SETUP [05] Call ref : 00 32
| SENDING COMPLETE
| IE:[18] CHANNEL (l=1) a3 -> T2 : Any B channel
| IE:[6c] CALLING_NUMBER (l=11) -> 00 81 Num : 213938750
| IE:[70] CALLED_NUMBER (l=6) -> 80 Num : 10016
| [97] Locking shift. codeset : 7
| IE:[06] EI_IP_PAYLOADS (l=1) -> G729 Ece 0 Vad 0
| IE:[0a] EI_RTP_INFO (l=30)
| -> stop_packet=0 stop_rtp=0 h323=1 wc=0 rf=0 udp=0 rqm=0
| -> Transm_Bande=0 detection_Q23=1
| -> Port RTP = 16518, IPv4 : 10. 20. 50. 254.
| -> Port RTCP SR = 16519, IPv4 : 10. 20. 50. 254.
| -> Port RTCP RR = 16519, IPv4 : 10. 20. 50. 254.
| -> Port Fax = 0, IPv4 : 0. 0. 0. 0.
| (146293:000222:04185) 4185: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 29 desti: 0 source: 15 cryst: 1 cpl: 0 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : CALL PROC (02) Call ref : 80 32
| [9f] Non-locking shift. codeset : 7
| IE:[07] EI_IP_QOS (l=3) b8 a0 00
| IE:[18] CHANNEL (l=3) a8 83 81 -> T2 : No B channel
| (146293:000223:04185) 4185: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 60 desti: 0 source: 15 cryst: 1 cpl: 0 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : ALERT (01) Call ref : 80 32
| IE:[06] EI_IP_PAYLOADS (l=2) : (COMP/ECE/VAD) -> G729/1/0 G711a/1/0
| -> stop_packet=0 stop_rtp=0 h323=0 wc=0 rf=0 udp=0 rqm=0
| -> Transm_Bande=1 detection_Q23=1 dtmf_payload=96
| -> Port RTP = 32716, IPv4 : 10. 20. 51. 10.
| -> Port RTCP SR = 32717, IPv4 : 10. 20. 51. 10.
| -> Port RTCP RR = 32717, IPv4 : 10. 20. 51. 10.
| -> Port Fax = 32719, IPv4 : 10. 20. 51. 10.
| IE:[1e] PROGRESS_ID (l=2) 81 88
| (146293:000225:04185) 4185: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 55 desti: 0 source: 15 cryst: 1 cpl: 0 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : FACILITY [62] Call ref : 80 32
| IE:[06] EI_IP_PAYLOADS (l=1) -> G729 Ece 1 Vad 0
| (146313:000227:04185) 4185: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 72 desti: 0 source: 15 cryst: 1 cpl: 0 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : CONNECT (07) Call ref : 80 32
| IE:[28] DISPLAY (l=5) `10016`
| -> Port RTP = 32514, IPv4 : 10. 20. 51. 123.
| -> Port RTCP SR = 32515, IPv4 : 10. 20. 51. 123.
| -> Port RTCP RR = 32515, IPv4 : 10. 20. 51. 123.
| IE:[4c] CONNECTED_NUMBER (l=7) -> 01 81 Num : 10016
| (146313:000229:04185) 4185: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| (146314:000231:04237) Concatenated-Physical-Event :
| long: 18 desti: 0 source: 0 cryst: 1 cpl: 0 us: 0 term: 0 type a5
| tei: 0 >>>> message received : CONNECT ACK (0f) Call ref : 00 32
| (146314:000232:04237) Concatenated-Physical-Event :
| long: 22 desti: 0 source: 0 cryst: 1 cpl: 0 us: 0 term: 0 type a5
| tei: 0 >>>> message received : RELEASE [4d] Call ref : 00 32
| IE:[08] CAUSE (l=2) 81 e4 -> [e4] INVALID INFORMATION ELEMENT CONTENTS
| (146314:000233:04185) 4185: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 22 desti: 0 source: 15 cryst: 1 cpl: 0 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : 80 32
| IE:[08] CAUSE (l=2) 81 90 -> [90] NORMAL CALL CLEARING
| SENDING COMPLETE
ACSE R10.0
From my point of view - some problem on Cisco site.
Cisco send - CONNECT ACK and RELEASE. If exist some problem - I think Cisco need to send STATUS message (with IE:[08] CAUSE (l=2) 81 e4 -> [e4] INVALID INFORMATION ELEMENT CONTENTS).
I not understand why Cisco disconnect call.
For "outgoing OXE calls drop after 30s" - OXE or Cisco send DISCONNECT?
