How to identify switched off phones
Mr_41Magnum
Post by Mr_41Magnum »
how can I find DECT phones that have been switched off?
Tom
Re: How to identify switched off phones
I don't know if it works for DECT phones, but maybe the "listerm" command on the console ?
Mr_41Magnum
No, it doesn't.
And "listout" doesn't work either on DECT phones :-(
ahqswitchroom4466
Post by ahqswitchroom4466 »
if you create dect phone set type GAP+. you can see your dect phone status
dect phone status command dectsets
if your dectphone out of service you see its dereigester
Md Afzal Hossain
System Admin
Return to “PWT/DECT System”
