PHD Relay
Motia Tenteng
PHD Relay
Post by Motia Tenteng »
How do I use PHD Relay in OXO?
Motia. 8)
henk1964
Re: PHD Relay
Post by henk1964 »
Start a trouble ticket with Alcatel explaining your problem.
They will send you a file you can load with PHD Relay.
Make a few call or sometime wait till the problem returns.
Omni makes a logfile localy
Copy this file to PC using PHD Relay and mail it to your support engineer.
Thats it ;-)
Motia Tenteng
Re: PHD Relay
Hi Henk,
Thanks for your reply. Is there no other way I can view the log myself on the ISDN trunks with the OXO? Nothing through HTTP?
Motia.
et
Re: PHD Relay
Post by et »
From OMC600/15.1b you can use PHD instead of PHDrelay with R5 and R6 of OXO. More info in TC 0113 of OXO.
Motia Tenteng
Re: PHD Relay
Thanks ET,
I'd look for the latest release of the OMC.
Cheers
Return to “MAIN”
