Windows 10 crashing
PhilippR
Windows 10 crashing
Post by PhilippR »
we are using IpDesktopSoftphone in the newest Version and are having big Problems with the new Windows 10 1809 Update.
From the Moment the Computer upgraded the Softphone is not working correctly anymore.
It crashes directly if you try to start it or if you try to enter your Phone number.
Is anyone experiencing similar issues with the new Windows Update?
Any help is appreciated.
Philipp
Re: Windows 10 crashing
Have you tried to uninstall and re-install ?
sergejvb
Post by sergejvb »
Hi all,
Any update on this?
We are also having issues with IpDesktopSoftphone 11.1.27 on Win10 1809.
Thanks in advance!
Michael_AT
Post by Michael_AT »
If using McAffee stop virus scanner and try to start IPDesktopSoftPhone.
Isalcatel
Post by Isalcatel »
have you turned off/stopped the WinDefender? Antivirus? Firewall? These thing use to prevent the execution of some software like IpDeskphone, Pimphony, etc.
Return to “Ip Desktop Softphone”
