4760 configuration errors.
CoastHills
Post by CoastHills »
Whenever I try to run a synchronization or a backup the system errors out, there seems to be something wrong with the network number and subnetwork number but even when I delete all the information out of the technical directory and rebuild I still get the same problem.
Carl
What's the error ?
What does it says ?
gundam
Post by gundam »
Try this:
If the PCX is in network 0 and Node 4.
When creating the 4400 node in 4760: check if the subnetwotk is 0 and node is 4.
if not you might have issue.
jazzn2day
Double check
Post by jazzn2day »
double check that what your system says in netadmin option 2 (network # node #) is also what it says in MGR/System
That has to match whatever your subnetwork and node say in 4760.
What version of 4760? The older ones need you to do some trickier stuff sometimes.
CoastHills
4760 mostly all better
Had to make my subnetwork number match the network number, the actual network number in the 4760 does not match. I think I remember something about that in class.
RuSt
Post by RuSt »
Remember 4760 Networknb. you can choose whatever you want.
4760 Subnetw.nb. MUST match the 4400 networknb.
4760 Nodenb. = 4400 nodenumber.
4400 nodenumber = Netw.nb*100 +nodenb.
If you have network 2 and node 4, the nodenumber = 204 (2*100+4)
Return to “OmniVista 4760”
