No audio on blind transfer from SIP trunk
pmvgrocha
Hello all,
i'm struggling on this one.
Here's the scenario, one OXE (site A) with a SIP trunk connection to an OXO (Site B).
When a user from site B calls to a user from site A, he answer the call and transfer it to another user (from the same site).
Option 1: He waits for the user to answer and then transfer the call.
Option 2: He transfer the call without waiting for the user to answer it (blind/unattended transfer).
The first option works well, both users from different sites can hear each other.
But testing option 2, we have no audio on both ways...
Anyone can figure out this one?
Thanks in advance!
Thanks in advance!
Re: No audio on blind transfer from SIP trunk
SIP TG - ABC-F or ISDN all countries?
PBX prefixes in DPNSS - managed on PBX or not?
pmvgrocha
Hello Vad, thank you so much for your reply and for helping those with some problem.
Well, i was checking my client oxe today and i noticed that SIP TG Q931 Signal Variant is defined as ABC-F.
I search for those prefix and did not find anything with that name, so i assume that is not created. I also tried to create a prefix with that meaning but i found none.
Hope you can help me.
Thanks!
Thanks!
Hi there
Did you capture traces of the call? Could you show us?
With traces we can see SIP messages and try to identify any reason. What is the network topology? Are OXE and OXO on the same network? IP addresses of the PABX?
Best regards.
Best regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
ACFE OXE R12
ACFE OXO C R3
pmvgrocha
Hello Enio,
thank you so much for your reply. Well here's the trace. But let me correct this sentence "But testing option 2, we have no audio on both ways...", in fact the call is dropped and on site B it is a Cisco Call Manager not an OXO.
So, answering to your questions, OXE and Cisco are not on the same network. OXE is on 10.82.251.3 and Cisco Call Manager at 10.80.30.6.
The scenario:
User 2422 at Cisco CM calls to user 11799 at Alcatel OXE. He answer the call and transfers (blind) it to another user and the call just dropped.
At some point reading the trace i see a "SIP/2.0 404 Not Found" message and then a bye one.
I hope you can help me with this one.
Thanks once again!
(1)cs-scm-a> traced
** UNIX-trace-daemon started ... (static user group No 1) **
traced started ...
1557829565 -> Tue May 14 11:26:04 2019 SIP_EQT_RELEASE_ACK
Tue May 14 11:26:04 2019 [display_ipc_out] ------------- End ----------------
Tue May 14 11:26:04 2019 [CMotorCallManager::onIncomingEvent] state = TERMINATED_STATE.
Tue May 14 11:26:04 2019 111b[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Tue May 14 11:26:04 2019 111b[CMotorCall::unRegister] Remove eqt : 3511 diag : -1 from the map.
Tue May 14 11:26:04 2019 [CMotorCallManager::eraseCallwithEqt] erase 3511 -1.
Tue May 14 11:26:04 2019 [CMotorCallManager::onIncomingEvent] killSession.
Tue May 14 11:26:04 2019 [CMotorCallManager::onNotifyCallClosed] Call : 2971c51f50fef80a04521d01d8ef1806@10.82.251.3 is closed.
Tue May 14 11:26:04 2019 [CMotorCallManager::onNotifyCallClosed] Remove eqt from the map.
Tue May 14 11:26:04 2019 [exec_ipc] in end 5252.
Tue May 14 11:26:05 2019 111b [CMotorCall::clear_subscription] no subscription managed
Tue May 14 11:26:05 2019 111b[CMotorCall::~CMotorCall] Call : 2971c51f50fef80a04521d01d8ef1806@10.82.251.3 is being destructed.
Tue May 14 11:26:05 2019 111b[CMotorCall::~CMotorCall] number of available licenses are =39 .
1557829566 -> IsIP_Phone neqt(1036) false
1557829567 -> Tue May 14 11:26:05 2019 [CMotorCallManager::onNotifyCallClosed] Call : bc525b743d892084820d0bf4465b9070@10.200.128.2 is closed.
Tue May 14 11:26:05 2019 [CMotorCallManager::onNotifyCallClosed] Remove eqt from the map.
Tue May 14 11:26:07 2019 RECEIVE MESSAGE FROM NETWORK (10.80.30.6:5060 [UDP])
INVITE sip:11799@10.82.251.3:5060 SIP/2.0
Via: SIP/2.0/UDP 10.80.30.6:5060;branch=z9hG4bK78c362d7ece2a
From: "Hugo Colaco" <sip:2422@10.80.30.6>;tag=8207217~b279f502-0dfa-4b5f-bd68-6907adf40bb3-41807959
To: <sip:11799@10.82.251.3>
Date: Tue, 14 May 2019 10:27:52 GMT
Call-ID: ec7cc980-cda19828-589d9-61e500a@10.80.30.6
Supported: timer,resource-priority,replaces
Min-SE: 1800
User-Agent: Cisco-CUCM11.5
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Call-Info: <sip:10.80.30.6:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=VIDEO_UNSPECIFIED
Session-ID: 3bf626da04594f1c9f0ac2997bb41ba0;remote=00000000000000000000000000000000
Cisco-Guid: 3967601024-0000065536-0000054627-0102649866
P-Charging-Vector: icid-value="EC7CC980000100000000D562061E500A";icid-generated-at=cucmsub1;orig-ioi="IMS Inter Operator Identification"
Session-Expires: 1800
P-Asserted-Identity: "Hugo Colaco" <sip:2422@10.80.30.6>
Remote-Party-ID: "Hugo Colaco" <sip:2422@10.80.30.6>;party=calling;screen=yes;privacy=off
Contact: <sip:2422@10.80.30.6:5060>
Max-Forwards: 70
Content-Length: 0
1557829567 -> Tue May 14 11:26:07 2019 [CMotorCallManager::callFactory] For call : ec7cc980-cda19828-589d9-61e500a@10.80.30.6.
Tue May 14 11:26:07 2019 [CMotorCall :: CMotorCall()] Oxe_Version_Name = OmniPCX Enterprise R12.1 m2.300.23
Tue May 14 11:26:07 2019 SEND MESSAGE TO NETWORK (10.80.30.6:5060 [UDP]) (BUFF LEN = 304)
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Tue May 14 11:26:07 2019 1126[CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
Tue May 14 11:26:07 2019 [getFromHeader] look at the From.
Tue May 14 11:26:07 2019 [convertCSipURLIntoSipuri] uri = sip:2422@10.80.30.6.
Tue May 14 11:26:07 2019 [getFromHeader] clirPresent=0.
Tue May 14 11:26:07 2019 [getReqUriHeader] look at the requri.
Tue May 14 11:26:07 2019 [convertCSipURLIntoSipuri] uri = sip:11799@10.82.251.3:5060.
Tue May 14 11:26:07 2019 [CMotorCall::analyseRouting] TEL uri=0.
Tue May 14 11:26:07 2019 [CMotorCall::analyseRouting] 2422@10.80.30.6 NOT found in the dictionnary.
Tue May 14 11:26:07 2019 [isDomainFromExtGw] Host from request is : 10.80.30.6.
Tue May 14 11:26:07 2019 [isDomainFromExtGw] User from request is : 2422
Tue May 14 11:26:07 2019 [isDomainFromExtGw]--> GwExt=2
1557829567 -> Tue May 14 11:26:07 2019 [isDomainFromExtGw] CS : Selected gw 2
Tue May 14 11:26:07 2019 [CMotorCallManager::processNotInDico] 10.80.30.6 is from extGw 2.
Tue May 14 11:26:07 2019 1126[CMotorCall::getUserType] extGw=2.
Tue May 14 11:26:07 2019 [CGwMngData::isAuthenticationRequiredForThisClient] need auth=0.
Tue May 14 11:26:07 2019 1126[CMotorCall::setFilterUsedMode] To be traced = 0
Tue May 14 11:26:07 2019 1126[CMotorCall::onReceiveRequest] accepte? m_other_calling=1 gw=2.
Tue May 14 11:26:07 2019 1126[CMotorCall::toGatewayOrProxy] SIP_PRIVATE_TRANSIT_MODE=1.
Tue May 14 11:26:07 2019 1126[CMotorCall::toGatewayOrProxy] request for proxydomain=10.82.251.3.
Tue May 14 11:26:07 2019 [issipisdn_extgw] ABCF ExtGW
Tue May 14 11:26:07 2019 [isUserRegistred] getRegistration=11799.
Tue May 14 11:26:07 2019 [isUserRegistred] result=-1.
Tue May 14 11:26:07 2019 1126[CMotorCall::toGatewayOrProxy] req uri = unregistred.
Tue May 14 11:26:07 2019 1126[CMotorCall::toGatewayOrProxy] unregistred, request to gateway.
Tue May 14 11:26:07 2019 1126[CMotorCall::onReceiveRequest] state = INITIAL_STATE.
Tue May 14 11:26:07 2019 1126[CMotorCall::methodInviteReceived] nb available licenses=39 .
Tue May 14 11:26:07 2019 IsRainbowCall_2 pt_rema_free1=1
Tue May 14 11:26:07 2019 1126[CMotorCall::methodInviteReceived] CAC = 0
Tue May 14 11:26:07 2019 [receiveInviteMessage] Call: ec7cc980-cda19828-589d9-61e500a@10.80.30.6 eqt: -1 INITIAL_STATE received a message.
1557829567 -> Tue May 14 11:26:07 2019 [receiveInviteMessage] INFO present in Allow header
Tue May 14 11:26:07 2019 [receiveInviteMessage] UPDATE present in Allow header
Tue May 14 11:26:07 2019 [decodeInviteFrom].
Tue May 14 11:26:07 2019 Routing using Via Header
Tue May 14 11:26:07 2019 [getExtGWusingViaHeader]GwNumber =0, IPADDRESS 10.100.110.6
Tue May 14 11:26:07 2019 [getExtGWusingViaHeader]GwNumber =1, IPADDRESS 10.80.30.5
Tue May 14 11:26:07 2019 [getExtGWusingViaHeader]GwNumber =2, IPADDRESS 10.80.30.6
Tue May 14 11:26:07 2019 [getExtGWusingViaHeader]GwNumber =3, IPADDRESS 10.200.128.2
Tue May 14 11:26:07 2019 [getExtGWusingViaHeader]GwNumber =4, IPADDRESS 10.249.194.17
Tue May 14 11:26:07 2019 [getExtGWusingViaHeader]GwNumber =5, IPADDRESS 10.249.2.17
Tue May 14 11:26:07 2019 [getExtGWusingViaHeader]GwNumber =6, IPADDRESS 10.249.2.18
Tue May 14 11:26:07 2019 [getExtGWusingViaHeader]GwNumber =7, IPADDRESS 10.249.66.17
Tue May 14 11:26:07 2019 [getExtGWusingViaHeader]GwNumber =8, IPADDRESS 10.200.182.200
Tue May 14 11:26:07 2019 [getExtGWusingViaHeader]VIA(0) Via: SIP/2.0/UDP 10.80.30.6:5060;branch=z9hG4bK78c362d7ece2a
Tue May 14 11:26:07 2019 [getExtGWusingViaHeader]VIA found in GW 2
Tue May 14 11:26:07 2019 Found=2
Tue May 14 11:26:07 2019 [decodeInviteFromPAI_NEW].VIA routing handling
Tue May 14 11:26:07 2019 1126[CMotorCall::isExtGwTLSwithREINVITE] ExtGw NOT manged with TLS and refresh REINVITE
Tue May 14 11:26:07 2019 1126[CMotorCall::analyseSessionTimer] exit with uacGatewayMode=0 uacRefresher=0.
1557829567 -> Tue May 14 11:26:07 2019 [decodeInviteSDP] sdp=0
Tue May 14 11:26:07 2019 [receiveInviteMessage] NO 100rel REQUIRED for this call.
Tue May 14 11:26:07 2019 [CInitialState::receiveinvitemessage allow_update 0 prack_required 0
Tue May 14 11:26:07 2019 [receiveinvitemessage] get requri.
Tue May 14 11:26:07 2019 [decodeInviteTo].
Tue May 14 11:26:07 2019 [convertCSipURLIntoSipuri] uri = sip:11799@10.82.251.3.
Tue May 14 11:26:07 2019 [decodeInviteReferredBy].
Tue May 14 11:26:07 2019 [decodeInviteACSBU].
Tue May 14 11:26:07 2019 systemOption[BOOL_SIP_DIVERSION_INFO_TRANSIT]=0
Tue May 14 11:26:07 2019 [receiveInviteMessage] concatenating from header
Tue May 14 11:26:07 2019 [receiveInviteMessage] temp_fromuserinfo = 2422
Tue May 14 11:26:07 2019 [receiveInviteMessage] From_userinfo = 2422
Tue May 14 11:26:07 2019 ** SIP TRUNKING **
Tue May 14 11:26:07 2019 1126[sendLgEvtSipCreate] get pilot ok trunk : 115
Tue May 14 11:26:07 2019 [ipc_thread] Normal case : evt 10764
Tue May 14 11:26:07 2019 [ipc_thread] IPC Thread : Ipc reception 5260.
Tue May 14 11:26:07 2019 [ipc_thread] IPC Thread : TCL thread signaled.
Tue May 14 11:26:07 2019 [CMotorCallManager::insertCallwithEqt] CMotorCall 3507 inserted.
Tue May 14 11:26:07 2019 1126[sendLgEvtSipCreate] Event sent on eqt : 3507
Tue May 14 11:26:07 2019 [display_ipc_out] ------------ Begin ---------------
1557829567 -> Tue May 14 11:26:07 2019 Id : -1
Tue May 14 11:26:07 2019 INVITE
Tue May 14 11:26:07 2019 REQUEST URI : <> 11799@10.82.251.3:5060 ; user=name
Tue May 14 11:26:07 2019 FROM : <Hugo Colaco> 2422@10.80.30.6:5060 ; user=name
Tue May 14 11:26:07 2019 TO : <> 11799@10.82.251.3:5060 ; user=name
Tue May 14 11:26:07 2019 CAC : 0
Tue May 14 11:26:07 2019 CAC ADDRESS :
Tue May 14 11:26:07 2019 CAC-CSBU info : UNKNOWN
Tue May 14 11:26:07 2019 CLIR : 0
Tue May 14 11:26:07 2019 Prack Required : 0
Tue May 14 11:26:07 2019 Allow Update : 0
Tue May 14 11:26:07 2019 N_GW_EXT : 2
Tue May 14 11:26:07 2019 [display_ipc_out] ------------- End ----------------
Tue May 14 11:26:07 2019 1126[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Tue May 14 11:26:07 2019 [exec_ipc] in 5252.
Tue May 14 11:26:07 2019 [display_ipc_in] ------------ Begin ---------------
Tue May 14 11:26:07 2019 neqt : 3507 Id : -1
Tue May 14 11:26:07 2019 INFORMATIONAL
Tue May 14 11:26:07 2019 xx : 80
Tue May 14 11:26:07 2019 RELATIVE REQUEST : INVITE
Tue May 14 11:26:07 2019 [display_ipc_in] ------------- End ----------------
Tue May 14 11:26:07 2019 [CMotorCallManager::onIncomingEvent] an event 10764 arrived on the eqt 3507 -1.
Tue May 14 11:26:07 2019 [CMotorCallManager::onIncomingEvent] state = PROCEEDING_STATE.
Tue May 14 11:26:07 2019 [onIncomingEvent] INFORMATIONAL arrived.
Tue May 14 11:26:07 2019 [receiveInformationalEvent] Call: ec7cc980-cda19828-589d9-61e500a@10.80.30.6 eqt: 3507 PROCEEDING_STATE received an event.
1557829568 -> Tue May 14 11:26:07 2019 [issipisdn_extgw] ABCF ExtGW
Tue May 14 11:26:07 2019 1126[CMotorCall::emitInformationalMessage] PAI
-Asserted-Identity: "11799" <sip:11799@10.82.251.3;user=phone>
Tue May 14 11:26:07 2019 1126[CMotorCall::buildContact] Contact: sip:10.82.251.3
Tue May 14 11:26:07 2019 1126[CMotorCall::emitInformationMessage] cause=-2
Tue May 14 11:26:07 2019 SEND MESSAGE TO NETWORK (10.80.30.6:5060 [UDP]) (BUFF LEN = 564)
SIP/2.0 180 Ringing
Allow: INVITE, ACK, CANCEL, BYE, PRACK, NOTIFY, REFER, SUBSCRIBE, OPTIONS, UPDATE
User-Agent: OmniPCX Enterprise R12.1 m2.300.23
P-Asserted-Identity: "11799" <sip:11799@10.82.251.3;user=phone>
To: <sip:11799@10.82.251.3>;tag=031ec7a4408b1c1f87b47bb430cdfe6a
CSeq: 101 INVITE
Content-Length: 0
Tue May 14 11:26:07 2019 [convertIPStrIntoTuipv] 10.80.30.6 => 10.80.30.6
Tue May 14 11:26:07 2019 [isIpAddressType] YES.
Tue May 14 11:26:07 2019 [exec_ipc] in end 5252.
Tue May 14 11:26:08 2019 1121 [CMotorCall::clear_subscription] no subscription managed
Tue May 14 11:26:08 2019 1121[CMotorCall::~CMotorCall] Call : bc525b743d892084820d0bf4465b9070@10.200.128.2 is being destructed.
1557829570 -> Tue May 14 11:26:10 2019 [ipc_thread] Normal case : evt 10765
Tue May 14 11:26:10 2019 [ipc_thread] IPC Thread : Ipc reception 5260.
Tue May 14 11:26:10 2019 [ipc_thread] IPC Thread : TCL thread signaled.
Tue May 14 11:26:10 2019 [exec_ipc] in 5252.
Tue May 14 11:26:10 2019 [display_ipc_in] ------------ Begin ---------------
Tue May 14 11:26:10 2019 neqt : 3507 Id : -1
Tue May 14 11:26:10 2019 SUCCESSFUL
Tue May 14 11:26:10 2019 xx : 0
Tue May 14 11:26:10 2019 RELATIVE REQUEST : INVITE
Tue May 14 11:26:10 2019 CLIR : 0
Tue May 14 11:26:10 2019 COLP : 0
Tue May 14 11:26:10 2019 CAC-CSBU info : UNKNOWN
Tue May 14 11:26:10 2019 CATEGORY : PRIVATE
Tue May 14 11:26:10 2019 TranferNotAllowed : FALSE
Tue May 14 11:26:10 2019 SDP :
Tue May 14 11:26:10 2019 ADDRESS : 10.82.251.4 :32876
Tue May 14 11:26:10 2019 ALGOS :
Tue May 14 11:26:10 2019 PCMA
Tue May 14 11:26:10 2019 G729
Tue May 14 11:26:10 2019 G723
Tue May 14 11:26:10 2019 97
Tue May 14 11:26:10 2019 DIRECTION : SEND & RECEIVE
Tue May 14 11:26:10 2019 video index : 0
Tue May 14 11:26:10 2019 crypto index : 0
Tue May 14 11:26:10 2019 [display_ipc_in] ------------- End ----------------
Tue May 14 11:26:10 2019 [CMotorCallManager::onIncomingEvent] an event 10765 arrived on the eqt 3507 -1.
Tue May 14 11:26:10 2019 [CMotorCallManager::onIncomingEvent] state = PROCEEDING_STATE.
Tue May 14 11:26:10 2019 [onIncomingEvent] SUCCESSFUL arrived.
Tue May 14 11:26:10 2019 [onIncomingEvent] relative_request = 10752
1557829570 -> Tue May 14 11:26:10 2019 [CProceedingState::receiveSuccessfulEvent] Call: ec7cc980-cda19828-589d9-61e500a@10.80.30.6 eqt: 3507 PROCEEDING_STATE received an event.
Tue May 14 11:26:10 2019 [issipisdn_extgw] ABCF ExtGW
Tue May 14 11:26:10 2019 1126[CMotorCall::emitSuccessfulMessage] uacGatewayMode=0 uacRefresher=0.
Tue May 14 11:26:10 2019 1126[CMotorCall::emitSuccesfulMessage] Offer sdp.
Tue May 14 11:26:10 2019 SEND MESSAGE TO NETWORK (10.80.30.6:5060 [UDP]) (BUFF LEN = 977)
SIP/2.0 200 OK
Supported: replaces,timer,path,100rel
Session-Expires: 1800;refresher=uas
P-Alcatel-CSBU: categparty=internal
Content-Type: application/sdp
CSeq: 101 INVITE
Content-Length: 337
v=0
o=OXE 1557829567 1557829567 IN IP4 10.82.251.3
s=abs
c=IN IP4 10.82.251.4
t=0 0
m=audio 32876 RTP/AVP 8 18 4 97
a=sendrecv
a=rtpmap:8 PCMA/8000
a=ptime:20
a=maxptime:30
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
a=rtpmap:4 G723/8000
a=ptime:30
a=maxptime:30
a=rtpmap:97 telephone-event/8000
1557829570 -> Tue May 14 11:26:10 2019 [convertIPStrIntoTuipv] 10.80.30.6 => 10.80.30.6
Tue May 14 11:26:10 2019 [isIpAddressType] YES.
Tue May 14 11:26:10 2019 1126[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Tue May 14 11:26:10 2019 [exec_ipc] in end 5252.
Tue May 14 11:26:10 2019 RECEIVE MESSAGE FROM NETWORK (10.80.30.6:5060 [UDP])
ACK sip:10.82.251.3 SIP/2.0
Via: SIP/2.0/UDP 10.80.30.6:5060;branch=z9hG4bK78c376d8f1817
Max-Forwards: 70
CSeq: 101 ACK
Session-ID: 3bf626da04594f1c9f0ac2997bb41ba0;remote=9e4a16cc3f74b1c1e970bb2ab8207217
Content-Length: 242
v=0
o=CiscoSystemsCCM-SIP 8207217 1 IN IP4 10.80.30.6
s=SIP Call
c=IN IP4 10.80.31.232
b=TIAS:64000
b=CT:64
b=AS:64
t=0 0
m=audio 22272 RTP/AVP 8 97
a=ptime:20
a=fmtp:97 0-15
Tue May 14 11:26:10 2019 1126[CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
Tue May 14 11:26:10 2019 1126[CMotorCall::onReceiveRequest] s=0 d=0 v=0 o=1.
Tue May 14 11:26:10 2019 1126[CMotorCall::onReceiveRequest] state = ACCEPTED_STATE.
1557829570 -> Tue May 14 11:26:10 2019 [receiveAckMessage] Call: ec7cc980-cda19828-589d9-61e500a@10.80.30.6 eqt: 3507 ACCEPTED_STATE received a message.
Tue May 14 11:26:10 2019 [checkSdpValidity] Sdp contains 1 media description(s).
Tue May 14 11:26:10 2019 [checkSdpValidity] without video control.
Tue May 14 11:26:10 2019 [checkSdpValidity] media audio.
Tue May 14 11:26:10 2019 [convertSdpIntoTsdp] Sdp contains 1 media description(s).
Tue May 14 11:26:10 2019 [convertAudioMedia] The audio media contains 2 format(s).
Tue May 14 11:26:10 2019 [convertAudioMedia] Format 0 is 8 opt syst G711=0.
Tue May 14 11:26:10 2019 [convertAudioMedia] Format 1 is 97 opt syst G711=0.
Tue May 14 11:26:10 2019 [convertAudioMedia] invalid Direction in this media part.
Tue May 14 11:26:10 2019 [convertIPStrIntoTuipv] 10.80.31.232 => 10.80.31.232
Tue May 14 11:26:10 2019 [display_sdp] address =10.80.31.232
Tue May 14 11:26:10 2019 [display_sdp] codecs =0.
Tue May 14 11:26:10 2019 [display_sdp] codecs =97.
Tue May 14 11:26:10 2019 [display_sdp] direction=0.
Tue May 14 11:26:10 2019 [receiveAckMessage] g711u: 255 g711A: 255 g723: 255 g729: 255.
Tue May 14 11:26:10 2019 1126[emitEventToMonitel] CAC = 0 eqtCAC = -1
Tue May 14 11:26:10 2019 1126[emitEventToMonitel] cacUsed=0 eqtCac=-1
Tue May 14 11:26:10 2019 1126[emitEventToMonitel] displayIPCMessageOut
Tue May 14 11:26:10 2019 ** SIP TRUNKING **
Tue May 14 11:26:10 2019 [sendLgEvtSip] Event sent on eqt : 3507 Id :-1
Tue May 14 11:26:10 2019 [display_ipc_out] ------------ Begin ---------------
1557829572 -> IsIP_Phone neqt(2293) false
1557829573 -> IsIP_Phone neqt(822) false
1557829573 -> Tue May 14 11:26:10 2019 Id : -1
Tue May 14 11:26:10 2019 ACK
Tue May 14 11:26:10 2019 ADDRESS : 10.80.31.232 :22272
Tue May 14 11:26:10 2019 [display_ipc_out] ------------- End ----------------
Tue May 14 11:26:10 2019 [receiveAckMessage] continue with session Timer
1557829577 -> Tue May 14 11:26:17 2019 [ipc_thread] Normal case : evt 10753
Tue May 14 11:26:17 2019 [ipc_thread] IPC Thread : Ipc reception 5260.
Tue May 14 11:26:17 2019 [ipc_thread] IPC Thread : TCL thread signaled.
Tue May 14 11:26:17 2019 [exec_ipc] in 5252.
Tue May 14 11:26:17 2019 [display_ipc_in] ------------ Begin ---------------
Tue May 14 11:26:17 2019 neqt : 3507 Id : -1
Tue May 14 11:26:17 2019 RE_INVITE
Tue May 14 11:26:17 2019 SDP :
Tue May 14 11:26:17 2019 ADDRESS : 10.82.251.4 :32876
Tue May 14 11:26:17 2019 ALGOS :
Tue May 14 11:26:17 2019 PCMA
Tue May 14 11:26:17 2019 97
Tue May 14 11:26:17 2019 DIRECTION : SEND ONLY
Tue May 14 11:26:17 2019 video index : 0
Tue May 14 11:26:17 2019 crypto index : 0
Tue May 14 11:26:17 2019 [display_ipc_in] ------------- End ----------------
Tue May 14 11:26:17 2019 [CMotorCallManager::onIncomingEvent] an event 10753 arrived on the eqt 3507 -1.
Tue May 14 11:26:17 2019 [CMotorCallManager::onIncomingEvent] state = COMPLETED_STATE.
Tue May 14 11:26:17 2019 [onIncomingEvent] RE_INVITE arrived.
Tue May 14 11:26:17 2019 [receiveReInviteEvent] Call: ec7cc980-cda19828-589d9-61e500a@10.80.30.6 eqt: 3507 COMPLETED_STATE received an event.
Tue May 14 11:26:17 2019 1126[emitReInviteMessage]--> Incoherent content type
Tue May 14 11:26:17 2019 [issipisdn_extgw] ABCF ExtGW
Tue May 14 11:26:17 2019 1126[CMotorCall::emitReInviteMessage] uacGatewayMode=1 uacRefresher=1.
Tue May 14 11:26:17 2019 SEND MESSAGE TO NETWORK (10.80.30.6:5060 [UDP]) (BUFF LEN = 875)
INVITE sip:2422@10.80.30.6:5060 SIP/2.0
Session-Expires: 1800;refresher=uac
Min-SE: 900
To: sip:2422@10.80.30.6;tag=8207217~b279f502-0dfa-4b5f-bd68-6907adf40bb3-41807959
From: sip:11799@10.82.251.3;tag=031ec7a4408b1c1f87b47bb430cdfe6a
CSeq: 1860013202 INVITE
Via: SIP/2.0/UDP 10.82.251.3;branch=z9hG4bK03e741c3f7362dd795f8af6a4ccdd006
Max-Forwards: 70
Content-Length: 212
v=0
o=OXE 1557829567 1557829568 IN IP4 10.82.251.3
s=abs
t=0 0
m=audio 32876 RTP/AVP 8 97
a=sendonly
a=ptime:20
a=maxptime:30
1557829577 -> Tue May 14 11:26:17 2019 [convertIPStrIntoTuipv] 10.80.30.6 => 10.80.30.6
Tue May 14 11:26:17 2019 [isIpAddressType] YES.
Tue May 14 11:26:17 2019 1126[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Tue May 14 11:26:17 2019 [exec_ipc] in end 5252.
Tue May 14 11:26:17 2019 RECEIVE MESSAGE FROM NETWORK (10.80.30.6:5060 [UDP])
SIP/2.0 100 Trying
From: <sip:11799@10.82.251.3>;tag=031ec7a4408b1c1f87b47bb430cdfe6a
To: "Hugo Colaco" <sip:2422@10.80.30.6>;tag=8207217~b279f502-0dfa-4b5f-bd68-6907adf40bb3-41807959
Date: Tue, 14 May 2019 10:28:02 GMT
Server: Cisco-CUCM11.5
Content-Length: 0
Tue May 14 11:26:17 2019 102 [CCallManager::onIncomingResponse]
Tue May 14 11:26:17 2019 [receiveInformationalMessage] Call: ec7cc980-cda19828-589d9-61e500a@10.80.30.6 eqt: 3507 MODIFICATION_PROCEEDING_STATE received a message.
SIP/2.0 200 OK
Supported: replaces
Supported: Geolocation
Require: timer
Remote-Party-ID: "Hugo Colaco" <sip:2422@10.80.30.6>;party=called;screen=yes;privacy=off
Content-Length: 254
v=0
o=CiscoSystemsCCM-SIP 8207217 2 IN IP4 10.80.30.6
s=SIP Call
b=TIAS:64000
b=CT:64
b=AS:64
t=0 0
a=ptime:20
a=recvonly
a=fmtp:97 0-15
1557829577 -> Tue May 14 11:26:17 2019 102 [CCallManager::onIncomingResponse]
Tue May 14 11:26:17 2019 [CForkedBranch::setFinalResponse] response=200.
Tue May 14 11:26:17 2019 1126[CMotorCall::chooseBestResponse] pForkedBranch=0x85a4530 iResponseCode=2000.
Tue May 14 11:26:17 2019 1126[CMotorCall::chooseBestResponse] last iResponseCode=200.
Tue May 14 11:26:17 2019 [CForkedBranch::setFinalResponse] pResponse=0x8551f88.
Tue May 14 11:26:17 2019 1126[CMotorCall::chooseBestResponse] next branch.
Tue May 14 11:26:17 2019 [receiveSuccessfulMessage] Call: ec7cc980-cda19828-589d9-61e500a@10.80.30.6 eqt: 3507 MODIFICATION_PROCEEDING_STATE received a message.
Tue May 14 11:26:17 2019 1126[CMotorCall::isExtGwTLSwithREINVITE] ExtGw NOT manged with TLS and refresh REINVITE
Tue May 14 11:26:17 2019 1126[CMotorCall::analyseSessionTimer] exit with uacGatewayMode=1 uacRefresher=1.
Tue May 14 11:26:17 2019 [convertSdpIntoTsdp] Sdp contains 1 media description(s).
Tue May 14 11:26:17 2019 [convertAudioMedia] The audio media contains 2 format(s).
Tue May 14 11:26:17 2019 [convertAudioMedia] Format 0 is 8 opt syst G711=0.
Tue May 14 11:26:17 2019 [convertAudioMedia] Format 1 is 97 opt syst G711=0.
Tue May 14 11:26:17 2019 [convertIPStrIntoTuipv] 10.80.31.232 => 10.80.31.232
Tue May 14 11:26:17 2019 [display_sdp] address =10.80.31.232
Tue May 14 11:26:17 2019 [display_sdp] codecs =0.
Tue May 14 11:26:17 2019 [display_sdp] codecs =97.
Tue May 14 11:26:17 2019 [display_sdp] direction=2.
Tue May 14 11:26:17 2019 [receiveSuccessfulMessage] ccal crypted = 0.
1557829577 -> Tue May 14 11:26:17 2019 [receiveSuccessfulMessage] T38 = 0.
Tue May 14 11:26:17 2019 1126[emitEventToMonitel] CAC = 0 eqtCAC = -1
Tue May 14 11:26:17 2019 1126[emitEventToMonitel] cacUsed=0 eqtCac=-1
Tue May 14 11:26:17 2019 1126[emitEventToMonitel] displayIPCMessageOut
Tue May 14 11:26:17 2019 ** SIP TRUNKING **
Tue May 14 11:26:17 2019 [sendLgEvtSip] Event sent on eqt : 3507 Id :-1
Tue May 14 11:26:17 2019 [ipc_thread] Normal case : evt 10754
Tue May 14 11:26:17 2019 [display_ipc_out] ------------ Begin ---------------
Tue May 14 11:26:17 2019 Id : -1
Tue May 14 11:26:17 2019 SUCCESSFUL
Tue May 14 11:26:17 2019 xx : 0
Tue May 14 11:26:17 2019 RELATIVE REQUEST : RE_INVITE
Tue May 14 11:26:17 2019 CAC-CSBU info : UNKNOWN
Tue May 14 11:26:17 2019 CLIR : 0
Tue May 14 11:26:17 2019 COLP : 0
Tue May 14 11:26:17 2019 ADDRESS : 10.80.31.232 :22272
Tue May 14 11:26:17 2019 DIRECTION : RECEIVE ONLY
Tue May 14 11:26:17 2019 [display_ipc_out] ------------- End ----------------
Tue May 14 11:26:17 2019 1126[CMotorCall::onReceiveResponse] retrans=0, status=200 extGw=2.
Tue May 14 11:26:17 2019 1126[CMotorCall::onReceiveResponse] INVITE case => cancelAllCancelableForkedBranch.
1557829577 -> Tue May 14 11:26:17 2019 1126[CMotorCall::cancelAllCancelableForkedBranch] nb branch=1.
Tue May 14 11:26:17 2019 1126[CMotorCall::cancelAllCancelableForkedBranch] retrans=0.
Tue May 14 11:26:17 2019 ACK
Tue May 14 11:26:17 2019 [CMotorCallManager::onIncomingEvent] an event 10754 arrived on the eqt 3507 -1.
Tue May 14 11:26:17 2019 [CMotorCallManager::onIncomingEvent] state = MODIFICATION_PROCEEDING_STATE.
Tue May 14 11:26:17 2019 [onIncomingEvent] ACK arrived.
Tue May 14 11:26:17 2019 [receiveAckEvent] Call: ec7cc980-cda19828-589d9-61e500a@10.80.30.6 eqt: 3507 MODIFICATION_PROCEEDING_STATE received an event.
Tue May 14 11:26:17 2019 1126[CMotorCall::emitAckMessage]
Tue May 14 11:26:17 2019 SEND MESSAGE TO NETWORK (10.80.30.6:5060 [UDP]) (BUFF LEN = 470)
ACK sip:2422@10.80.30.6:5060 SIP/2.0
CSeq: 1860013202 ACK
Via: SIP/2.0/UDP 10.82.251.3;branch=z9hG4bKaba6d453f3eda21021347eaf844bb8fa
Max-Forwards: 70
Content-Length: 0
Tue May 14 11:26:17 2019 [CModification_ProceedingState::receiveAckEvent] continue with session Timer
1557829579 -> Tue May 14 11:26:19 2019 [ipc_thread] Normal case : evt 10757
Tue May 14 11:26:19 2019 [ipc_thread] IPC Thread : Ipc reception 5260.
Tue May 14 11:26:19 2019 [ipc_thread] IPC Thread : TCL thread signaled.
Tue May 14 11:26:19 2019 [exec_ipc] in 5252.
Tue May 14 11:26:19 2019 [display_ipc_in] ------------ Begin ---------------
Tue May 14 11:26:19 2019 neqt : 3507 Id : -1
Tue May 14 11:26:19 2019 REFER
Tue May 14 11:26:19 2019 REFER TO : 10799@10.82.251.3:5060
Tue May 14 11:26:19 2019 REFER BY : 11799@10.82.251.3:5060
Tue May 14 11:26:19 2019 Neqt : 3507 dialogId : -1
Tue May 14 11:26:19 2019 CAC-CSBU info : UNKNOWN
Tue May 14 11:26:19 2019 [display_ipc_in] ------------- End ----------------
Tue May 14 11:26:19 2019 [CMotorCallManager::onIncomingEvent] an event 10757 arrived on the eqt 3507 -1.
Tue May 14 11:26:19 2019 [CMotorCallManager::onIncomingEvent] state = COMPLETED_STATE.
Tue May 14 11:26:19 2019 [onIncomingEvent] REFER arrived.
Tue May 14 11:26:19 2019 [CSubscriptionState::receiveReferEvent] Call: ec7cc980-cda19828-589d9-61e500a@10.80.30.6 eqt: 3507 SUBSCRIPTION_STATE received an event.
Tue May 14 11:26:19 2019 [emitReferMessage]Refer-To = ReferTo: sip:10799@10.82.251.3;user=phone
Tue May 14 11:26:19 2019 1126[CMotorCall::emitReferMessage] The REFER message is build with Replaces from Call: ec7cc980-cda19828-589d9-61e500a@10.80.30.6.
Tue May 14 11:26:19 2019 SEND MESSAGE TO NETWORK (10.80.30.6:5060 [UDP]) (BUFF LEN = 733)
REFER sip:2422@10.80.30.6:5060 SIP/2.0
Supported: timer,path,100rel
Refer-To: <sip:10799@10.82.251.3;user=phone?REPLACES=ec7cc980-cda19828-589d9-61e500a%4010.80.30.6%3bto-tag%3d8207217~b279f502-0dfa-4b5f-bd68-6907adf40bb3-41807959%3bfrom-tag%3d031ec7a4408b1c1f87b47bb430cdfe6a>
Referred-By: sip:11799@10.82.251.3
CSeq: 1860013203 REFER
Via: SIP/2.0/UDP 10.82.251.3;branch=z9hG4bK246b5960eecf316d479b9e394c71697c
Max-Forwards: 70
Content-Length: 0
1557829579 -> Tue May 14 11:26:19 2019 [convertIPStrIntoTuipv] 10.80.30.6 => 10.80.30.6
Tue May 14 11:26:19 2019 [isIpAddressType] YES.
Tue May 14 11:26:19 2019 [exec_ipc] in end 5252.
Tue May 14 11:26:19 2019 RECEIVE MESSAGE FROM NETWORK (10.80.30.6:5060 [UDP])
SIP/2.0 202 Accepted
Date: Tue, 14 May 2019 10:28:04 GMT
Content-Length: 0
Tue May 14 11:26:19 2019 102 [CCallManager::onIncomingResponse]
Tue May 14 11:26:19 2019 [CSubscriptionState::receiveResponseMessage] Call: ec7cc980-cda19828-589d9-61e500a@10.80.30.6 eqt: 3507 SUBSCRIPTION_STATE received a message.
Tue May 14 11:26:19 2019 1126[emitEventToMonitel] CAC = 0 eqtCAC = -1
Tue May 14 11:26:19 2019 1126[emitEventToMonitel] cacUsed=0 eqtCac=-1
Tue May 14 11:26:19 2019 1126[emitEventToMonitel] displayIPCMessageOut
Tue May 14 11:26:19 2019 ** SIP TRUNKING **
Tue May 14 11:26:19 2019 [sendLgEvtSip] Event sent on eqt : 3507 Id :-1
Tue May 14 11:26:19 2019 [display_ipc_out] ------------ Begin ---------------
Tue May 14 11:26:19 2019 Id : -1
Tue May 14 11:26:19 2019 SUCCESSFUL
1557829579 -> Tue May 14 11:26:19 2019 xx : 2
Tue May 14 11:26:19 2019 RELATIVE REQUEST : REFER
Tue May 14 11:26:19 2019 CLIR : 9
Tue May 14 11:26:19 2019 COLP : 64
Tue May 14 11:26:19 2019 [display_ipc_out] ------------- End ----------------
NOTIFY sip:10.82.251.3 SIP/2.0
Via: SIP/2.0/UDP 10.80.30.6:5060;branch=z9hG4bK78c3867483b08
From: sip:2422@10.80.30.6;tag=8207217~b279f502-0dfa-4b5f-bd68-6907adf40bb3-41807959
To: sip:11799@10.82.251.3;tag=031ec7a4408b1c1f87b47bb430cdfe6a
CSeq: 102 NOTIFY
Max-Forwards: 70
Event: refer
Subscription-State: active;expires=60
Content-Type: message/sipfrag;version=2.0
Content-Length: 20
SIP/2.0 100 Trying
Tue May 14 11:26:19 2019 1126[CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
Tue May 14 11:26:19 2019 1126[CMotorCall::onReceiveRequest] s=0 d=0 v=0 o=1.
Tue May 14 11:26:19 2019 1126[CMotorCall::onReceiveRequest] state = COMPLETED_STATE.
Tue May 14 11:26:19 2019 [CSubscriptionState::receiveNotifyMessage] Call: ec7cc980-cda19828-589d9-61e500a@10.80.30.6 eqt: 3507 SUBSCRIPTION_STATE received a message.
1557829579 -> Tue May 14 11:26:19 2019 [CSubscriptionState::receiveNotifyMessage] The Reason is: Trying.
Tue May 14 11:26:19 2019 [issipisdn_extgw] ABCF ExtGW
Tue May 14 11:26:19 2019 1126[CMotorCall::makeResponse] Reply directed to the last received request.
Tue May 14 11:26:19 2019 SEND MESSAGE TO NETWORK (10.80.30.6:5060 [UDP]) (BUFF LEN = 515)
SIP/2.0 200 OK
CSeq: 102 NOTIFY
Content-Length: 0
Via: SIP/2.0/UDP 10.80.30.6:5060;branch=z9hG4bK78c394580aa37
CSeq: 103 NOTIFY
Max-Forwards: 70
Event: refer
Subscription-State: terminated
Content-Length: 23
1557829579 -> Tue May 14 11:26:19 2019 1126[CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
Tue May 14 11:26:19 2019 [CSubscriptionState::receiveNotifyMessage] The Reason is: Not Found.
Tue May 14 11:26:19 2019 [CSubscriptionState::receiveNotifyMessage] a Successful message is sent bu Motor
SIP/2.0 200 OK
CSeq: 103 NOTIFY
Content-Length: 0
Tue May 14 11:26:19 2019 1126[CMotorCall::getOutgoingCall] outgoingCall:1
Tue May 14 11:26:19 2019 1126[CMotorCall::onSubscriptionTerminated] end of outgoing subscription.
Tue May 14 11:26:19 2019 1126[CMotorCall::onSubscriptionTerminated] Error!!!!! eqt=3507.-1.
Tue May 14 11:26:19 2019 [ipc_thread] Normal case : evt 10765
Tue May 14 11:26:19 2019 NOTIFY
Tue May 14 11:26:19 2019 Response : 404
1557829579 -> Tue May 14 11:26:19 2019 [display_ipc_out] ------------ Begin ---------------
Tue May 14 11:26:19 2019 xx : 0
Tue May 14 11:26:19 2019 RELATIVE REQUEST : NOTIFY
Tue May 14 11:26:19 2019 CLIR : 0
Tue May 14 11:26:19 2019 COLP : 0
Tue May 14 11:26:19 2019 [CMotorCallManager::onIncomingEvent] an event 10765 arrived on the eqt 3507 -1.
Tue May 14 11:26:19 2019 [onIncomingEvent] SUCCESSFUL arrived.
Tue May 14 11:26:19 2019 [onIncomingEvent] relative_request = 10758
Tue May 14 11:26:19 2019 [CSubscriptionState::receiveResponseEvent] Call: ec7cc980-cda19828-589d9-61e500a@10.80.30.6 eqt: 3507 SUBSCRIPTION_STATE received an event.
Tue May 14 11:26:19 2019 1126[CMotorCall::makeResponse] There is no open NOTIFY transaction.
Tue May 14 11:26:19 2019 [SIPAlarm] alarm level : 3
Tue May 14 11:26:19 2019 ALARM: [CSubscriptionState::receiveResponseEvent] Call: ec7cc980-cda19828-589d9-61e500a@10.80.30.6 eqt: 3507 SUBSCRIPTION_STATE failed to emit an Succesful message.
1557829579 -> Tue May 14 11:26:19 2019 ALARM: CPU main
Tue May 14 11:26:19 2019 [ipc_thread] Normal case : evt 10755
Tue May 14 11:26:19 2019 BYE
Tue May 14 11:26:19 2019 [CMotorCallManager::onIncomingEvent] an event 10755 arrived on the eqt 3507 -1.
Tue May 14 11:26:19 2019 [onIncomingEvent] BYE arrived.
Tue May 14 11:26:19 2019 [receiveByeEvent] Call: ec7cc980-cda19828-589d9-61e500a@10.80.30.6 eqt: 3507 COMPLETED_STATE received an event.
Tue May 14 11:26:19 2019 SEND MESSAGE TO NETWORK (10.80.30.6:5060 [UDP]) (BUFF LEN = 465)
BYE sip:2422@10.80.30.6:5060 SIP/2.0
CSeq: 1860013204 BYE
Via: SIP/2.0/UDP 10.82.251.3;branch=z9hG4bK5157248cb9de8a54f64a3d2a7bc6002c
Max-Forwards: 70
Content-Length: 0
Tue May 14 11:26:19 2019 1126[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
INVITE sip:10.82.251.3 SIP/2.0
Via: SIP/2.0/UDP 10.80.30.6:5060;branch=z9hG4bK78c3a5a58a6f1
CSeq: 104 INVITE
Max-Forwards: 70
Expires: 180
Min-SE: 1800
Content-Length: 0
1557829579 -> Tue May 14 11:26:19 2019 SEND MESSAGE TO NETWORK (10.80.30.6:5060 [UDP]) (BUFF LEN = 341)
SIP/2.0 100 Trying
CSeq: 104 INVITE
Content-Length: 0
Tue May 14 11:26:19 2019 1126[CMotorCall::onReceiveRequest] state = TERMINATED_STATE.
Tue May 14 11:26:19 2019 1126[CMotorCall::methodInviteReceived] nb available licenses=38 .
Tue May 14 11:26:19 2019 IsRainbowCall_2 pt_rema_free1=1
Tue May 14 11:26:19 2019 1126[CMotorCall::methodInviteReceived] CAC = 0
Tue May 14 11:26:19 2019 [receiveInviteMessage] Call: ec7cc980-cda19828-589d9-61e500a@10.80.30.6 eqt: 3507 TERMINATED_STATE received a not handled message.
Tue May 14 11:26:19 2019 [SIPAlarm] alarm level : 4
1557829579 -> Tue May 14 11:26:19 2019 ALARM: 21b2 [CTransCompletedState::createResponse] Response creation in completed state
Tue May 14 11:26:19 2019 ALARM: [receiveInviteMessage] Call: ec7cc980-cda19828-589d9-61e500a@10.80.30.6 eqt: 3507 TERMINATED_STATE failed to emit a RequestFailure message.
SIP/2.0 200 OK
Content-Length: 0
Tue May 14 11:26:19 2019 [CTerminatedState::receiveSuccessfulMessage] Call: ec7cc980-cda19828-589d9-61e500a@10.80.30.6 eqt: 3507 TERMINATED_STATE received a message.
1557829579 -> Tue May 14 11:26:19 2019 [sendLgEvtSip] Event sent on eqt : 3507 Id :-1
Tue May 14 11:26:19 2019 [ipc_thread] Normal case : evt 10773
Tue May 14 11:26:19 2019 RELATIVE REQUEST : BYE
Tue May 14 11:26:19 2019 SIP EQT RELEASED
Tue May 14 11:26:19 2019 [CMotorCallManager::onIncomingEvent] an event 10773 arrived on the eqt 3507 -1.
Tue May 14 11:26:19 2019 [CMotorCallManager::onIncomingEvent] The call with eqt: 3507 has released its equipment.
Tue May 14 11:26:19 2019 1126[CMotorCall::emitSipEqtReleaseAck] SIP_EQT_RELEASE_ACK
1557829581 -> Tue May 14 11:26:19 2019 ** SIP TRUNKING **
Tue May 14 11:26:19 2019 SIP_EQT_RELEASE_ACK
Tue May 14 11:26:19 2019 [CMotorCallManager::onIncomingEvent] state = TERMINATED_STATE.
Tue May 14 11:26:19 2019 1126[CMotorCall::unRegister] Remove eqt : 3507 diag : -1 from the map.
Tue May 14 11:26:19 2019 [CMotorCallManager::eraseCallwithEqt] erase 3507 -1.
Tue May 14 11:26:19 2019 [CMotorCallManager::onIncomingEvent] killSession.
Tue May 14 11:26:19 2019 [CMotorCallManager::onNotifyCallClosed] Call : ec7cc980-cda19828-589d9-61e500a@10.80.30.6 is closed.
Tue May 14 11:26:19 2019 [CMotorCallManager::onNotifyCallClosed] Remove eqt from the map.
Tue May 14 11:26:20 2019 1126 [CMotorCall::clear_subscription] no subscription managed
Tue May 14 11:26:20 2019 1126[CMotorCall::~CMotorCall] Call : ec7cc980-cda19828-589d9-61e500a@10.80.30.6 is being destructed.
Tue May 14 11:26:20 2019 1126[CMotorCall::~CMotorCall] number of available licenses are =39 .
Tue May 14 11:26:21 2019 [CMotorCallManager::onNotifyCallClosed] Call : 398db665c3c8fe859d2885d1e6e0d489 is closed.
Tue May 14 11:26:21 2019 [CMotorCallManager::onNotifyCallClosed] Remove eqt from the map.
1557829584 -> IsIP_Phone neqt(1583) false
^C
(1)cs-scm-a>
The scenario:
Thanks once again!
(1)cs-scm-a> traced
traced started ...
Min-SE: 1800
CSeq: 101 INVITE
Expires: 180
Max-Forwards: 70
Content-Length: 0
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Content-Length: 0
SIP/2.0 200 OK
CSeq: 101 INVITE
Content-Length: 337
v=0
s=abs
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
a=fmtp:18 annexb=no
a=ptime:20
a=maxptime:40
a=ptime:30
a=maxptime:30
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 242
v=0
s=SIP Call
b=TIAS:64000
b=CT:64
b=AS:64
t=0 0
a=ptime:20
a=fmtp:97 0-15
Min-SE: 900
Max-Forwards: 70
Content-Length: 212
v=0
s=abs
t=0 0
a=sendonly
a=ptime:20
a=maxptime:30
SIP/2.0 100 Trying
Content-Length: 0
SIP/2.0 200 OK
Supported: replaces
Require: timer
Content-Length: 254
v=0
s=SIP Call
b=TIAS:64000
b=CT:64
b=AS:64
t=0 0
a=ptime:20
a=recvonly
a=fmtp:97 0-15
Max-Forwards: 70
Content-Length: 0
Max-Forwards: 70
Content-Length: 0
Content-Length: 0
CSeq: 102 NOTIFY
Max-Forwards: 70
Event: refer
Content-Length: 20
SIP/2.0 100 Trying
SIP/2.0 200 OK
CSeq: 102 NOTIFY
Content-Length: 0
CSeq: 103 NOTIFY
Max-Forwards: 70
Event: refer
Content-Length: 23
SIP/2.0 200 OK
CSeq: 103 NOTIFY
Content-Length: 0
Max-Forwards: 70
Content-Length: 0
CSeq: 104 INVITE
Max-Forwards: 70
Expires: 180
Min-SE: 1800
Content-Length: 0
SIP/2.0 100 Trying
CSeq: 104 INVITE
Content-Length: 0
SIP/2.0 200 OK
Content-Length: 0
^C
(1)cs-scm-a>
1 - Can you check with SIP TG with Q931 signal variant "ISDN all countries"
2 - Create prefix - Local Feature, PCX address in DPNSS (any number, f.e. A00001)
pmvgrocha
Hi Vad,
thanks for your feedback.
I will try to change (probably i will need to create another SIP TG) to "ISDN All countries".
What do you mean by "DPNSS"?
Thanks!
Thanks!
DPNSS - Digital Private Network Signalling.
For networking, routing optimization etc Alcatel highly recommend to create prefix Local Feature, PCX address in DPNSS.
Not sure but if you check database ("checkdb" command) - you will have error about DPNSS prefix missing.
Hi pmvgrocha
I could check your reply just now.
I agree with vad and his answer would be mine too. Mainly check SIP TG with Q931 signal variant as ISDN all countries.
Best regards.
Best regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
ACFE OXE R12
ACFE OXO C R3
pmvgrocha
Hello all,
i've created a new SIP TG with Q931 as ISDN all countries, but i can't set it on my routing No. prefix, it seems that it only accepts ABC-F TG. Could you please check my screenshot attached?
Thank you so much.
Thank you so much.
