Hello to all Alcatel men and women
I have a problem with my E1 link on OXE common hardware release 9 (h1.301.50a).when an incoming call comes to system i received it respectively in different TS. for example one call comes to my system and received by TS 10 then its drop and i get miscall in my phone Immediately after that it comes from TS 11 and drop again then finally it works fine when comes from TS 12 . For drop calls i get "Temporary failure" message from ISDN in my Trace .
Have you any advice for this problem?
ISDN Temporary failure Message
Re: ISDN Temporary failure Message
Check with your provider how many TS are assigned from their side. And which side is configured to choose B-channels.
fery_s
Hello and thanks for your reply .choose B-channels is active in my side and unfortunately the provider not accept that problem caused by them
I exactly said them that i can not generate the call by my self and send it in different TS to my self.
You'd better switch it off on your side. An operator is suppose to choose B-channel.
