Good morning,
I'm new to the group and would like your help. I made the interconnection between Cisco and Alcatel through SIP trunk. Internal communication is working. In order to receive external calls, I created an abbreviation in Alcatel and this abbreviation accesses the sip trunk and dials the Cisco extension, but Cisco does not receive my cell number and I would like this to happen.
Can anyone help?
Thank you
Douglas
SiP Trunk DID
KoenC
Re: SiP Trunk DID
Hi DBasilio,
You have to check two things for starters:
1. Can the OXO reroute the external number to the Cisco when the OXO sets up the call (can you do CLIPspoofing)
- OMC > System Miscellaneous > Feature Design > Part 3
- Put the 'external diversion mode' from joining (by default) in Re-routing
--> Also check the CLIP labels (OMC > System Miscellaneous > Memory Read/Write > Debug labels and Other labels)
2. How did you configure your SIP public numbering?
- OMC > External Lines > SIP > SIP Public numbering
- put the same formats as the formats you receive from your Public SIP trunk, and the ones your Cisco expects
--> If you don't know which formats are delivered, trace a call. If you don't know which one is expected from your Cisco, look it up or test every one.
If these doesn't help, you should send your database and traces to a certified ALE partner who can help you with this kind of configuration errors.
Good luck.
Good luck.
Shermanpap
SiP Trunk DID
OK so I currently have:
1 x Samsung Ubigate iBG1004
2 x Samsung OfficeServ 7200 samsung extensions
BT Trunk & BT Fibre on BTNet uk
I am trying to replace OfficeServ servers with asterisk.
The only piece of documentation i have is an instruction from BT with an IP address to connect to.
I am led to believe Ubigate is a gateway allowing interoperability with various PBXes to be used on a BT Sip trunk.
I know the Internal IP address of Ubigate which is a SIP gateway I believe
I know the Internal/External IP of the Officeserv
My plan is to unplug Officeserv, give my asterisk the same IP as the officeserv and plug into the same lan cable leading to Ubigate.
My issue is registration settings. I have no username/password. I am led to believe this setup doesnt need one.
Do I just set the ubigate to be the sip proxy in my registration settings, with the main SIP server the IP BT has given me?
Any more info would be welcome, regards.
Re: SiP Trunk DID
Why you post this question in ALU PABX forum? Only for signature with link?
