No entries in Directory
This application replaces the OmniVista 4760
hawai50
Post by hawai50 »
Hi;
I have activated the directory license for 8770 but i can´t see the entries en Directory app after synchronization.
- Procesing directory and automatic creation are validated.
Any idea ?
Thanks in advance
Re: No entries in Directory
the création should be made from the directory module
create a new Organisational unity
under this new organistaion launch the SET==>PERSON
hawai50
Post by hawai50 »
Thanks for your help Haround, but I think the creation is automatic with the parameter " automatic creation " validated in node.
I can´t create 1xxxx users manually.
hawai50
Post by hawai50 »
Solved ..
MIPaixao
Post by MIPaixao »
how did you solve it? I have the problem that every time the name is changed and it already exists, an alarm is generated... I would like to turn it off!
MIPaixao
Post by MIPaixao »
hawai50 wrote: 01 Jul 2019 02:33Solved ..
Return to “OmniVista 8770”
