7210 SAS-T VLAN and dot1q Configuration
bdy
Post by bdy »
I have a customer who has purchased some Nokia 7210 SAS-T switches to replace their existing Access LAN switches
I am new to Nokia - and I can't see a straight forward way of configuring the simple VLAN and Trunking that exits on the old switches (Aruba)
I can see that the 7210-t is mainly a service based switch - but is there a way to configure it as a normal LAN Access Switch?
All we need is a dot1q trunk connecting the Nokia to an HPE Core switch Tagging a few VLANs
Possibly some LACP Aggregation on the uplinks
with untagged Access ports connected to local devices in these VLANs
Not sure this is the right switch for this job - but this was not our decision
Brian
paramount
Re: 7210 SAS-T VLAN and dot1q Configuration
Post by paramount »
Yes it's a service based switch, but it should definitely be able to do what you need.
For multiport VLANs etc., you can configure a VPLS, or for a simple port to port VLAN, you can use an epipe.. But on Nokia there are several things you need to do first:
  • Configure the port as an access port and also set the encapsulation type - configure port x/x/x - you may need to shut down the port first and then re-enable
    configure the service - configure service vpls xxx customer 1 create
    then add the port and vlans to the service: sap x/x/x:x create
    then no shutdown on all elements
If you'd like some prof services etc let me know.
Cheers
Paramount
franckorange
Post by franckorange »
Am pretty much new in nokia 7210 SAS-T
I will like to have command lines on creation of several vlans on one port
best regards
Return to “7210 SAS”
