Port 1/17 in down state
aviviis
Post by aviviis »
Hello
I have os6850 optics switch that port 1/17 in down state , i connect cpe to that port and the port always down , i change to another port and the port goes up , do you know dshell command that can check the hardware of the port ?
devnull
Re: Port 1/17 in down state
Post by devnull »
i don't know a dshell command. have you checked the config? rebooted the switch? used latest firmware?
paramount
Post by paramount »
Assuming you have checked autoneg and also swapped out SFP?
