OS6860 synchronization failed
HUSSAINQCS
Post by HUSSAINQCS »
I have OS6860 X8 in VC when i execute
write memory flash synchro I’m getting below error
What could be the possible reason ?
Re: OS6860 synchronization failed
in the knowledge base at ALE I have found the following:
This error message "ERROR: Copy running to certified succeeded; secondary synchronization failed" is seen, since there are few unwanted files and old pmd files present in the flash directory which fails to synchronize with master chassis.
Solution:
Once deleting the unwanted files, synchronization from the master chassis will be successful.
Return to “OmniSwitch 6865”
