apply snapshot
mayyola
apply snapshot
Post by mayyola »
hello,
i use generate a snapshot to backup the config on last month,and now want to restore it
but i use webview->system mgmt->sanpshot->appsnapshot
Path to Configuration Filename:/flah/snap1070808 then apply
Check File Syntax Only is no checked
but it can't reload the cofig
CLI
-> configuration apply snap1070808
Errors: 15
Log file name: snap1070808.1.err
->show configuration status
Running configuration and saved configuration are different
how can i reload the saved configuration
what's problem
thank you
