4038 Caller name display
dangermike
Post by dangermike »
I am using a IP touch 4038, and when i get a call i struggle to read the name of the caller as it cuts off the bottom 2-3 Pixels?
the rest of the display for the phone is perfect, only seems to be the caller name.
Any ideas? or is this just a "Feature" of the phone?
dangermike
Re: 4038 Caller name display
Hi, any ideas about this? is there away you can program font size?
hi
is it the callee an oxe's user ? Did u check Under user how the name will be displayed ? check also if it's Direct Abbrev.No Pref
exemple
Directory name : PosteDeNuit x
x Directory First Name : ATTHELP
Displayed Name : PosteDeNuit ATTH
