Appliance server installation
mtcl
Post by mtcl »
Hi experts
I plan to replace CPU7-2 by Appliance server.Is there any procedure to work with the Data Base. Since crystal 0 will be "reserved" by the Appliance Server, I don't think that I can "import" the existing database in the new CPU
Please advice
patmul39
Re: Appliance server installation
Post by patmul39 »
Are you upgrading the software at all or is it just a cpu with AS swap?
mtcl
Post by mtcl »
In fact we plan to centralize a few nodes. Therefore, an upgrade will take place
patmul39
Post by patmul39 »
Since it is an upgrade, the database translation should take care of shelf 0 and will assign a new shelf for the existing shelf 0. Be careful of the database and patch alignment.
mtcl
Post by mtcl »
What do you mean by "patch alignment ?
Shouldn't the database be translated from R11.2 to R12.3 ?
Return to “MAIN”
