DIALER V2.3 for OXE R12.x
Questions / Answer related to the dialer tool
Here is the new dialer for OXE R12.x
It might work with versions 11 and 10, but I did not test.
FTP to your CPU. Then
tar -zxvf dialer.tar.gz
chmod 755 dialer
Launch with "./dialer"
bsdeg
Re: DIALER V2.3 for OXE R12.x
Post by bsdeg »
which API are you using to dial?
I've been using a tool I derived from this thing that I found on pastebin after some wiresharking:
https://pastebin.com/YAJGws21
This seems to be using a SOAP API called XmlPhone.
Problem with that seems to be that once I log in using that API, PIMphony is silently logged out and never logged back in.
Were you able to solve that problem?
Hi.
I'm not using any APIs actually.
What you could do it use O2G API in your case.
See http://api.dspp.al-enterprise.com
alexeik
Post by alexeik »
hi frank
im using the dialer pretty often when ich implement SIP trunk witk OXE and audiocodes SBC. Sometimes i make new ars prefixes for this test. is it possible that prefixes like #50 dont work? if i choose a prefix witk only numbers everything is fine...
If you prefix your prefixes with * or # , put the number in between " ". IE: "#5018001234567"
alexeik
Post by alexeik »
ahh thx
Anyone can give me an update to see if the dialer works on R12.4 ?
alexeik
Post by alexeik »
yeah, tested 5 min ago, with latest patch 34c
Perfect, thank you !
blind0wl
Post by blind0wl »
Hi Frank,
I dont suppose you have the dialer code opensourced anywhere? If not, that's fine. I was hoping to understand how its doing what it's doing is all. Has got me out of some tight situations many times so thank you for your time in developing it over the years!
Return to “DIALER”
