Hi all,
i having OXE system R12.3 running with Dual CPU-8.
i configured for system working with Dual CPU active and test bascul command OK .
But whenever i accessed the MAIN CPU, the command promt ONLY show the local name ( it not show Local MAIN name). and tried to test both CPUs as main role still got the same behaviour.
Any pro help me to solve this issue ?
thanks
Ethernet interface setup
Netmask : 255.255.255.0
| Machine type | Local interface | Name | Address |
| local | Ethernet | cpu_a | 192.168.1.3 |
| local main | Ethernet | cpu_m | 192.168.1.4 |
| router | Ethernet | router | 192.168.1.254 |
<return> to continue.
CPU redundancy setup
| twin | Ethernet | cpu_b | 192.168.1.2 |
| twin main | Ethernet | cpu_m | 192.168.1.4 |
(1)cpu_a> role -b
MAIN stand-by CPU state : ACTIVE
(1)cpu_a> twin
Usage : twin [Redundancy Cpu Enable (y/n)]
Role and CPU positions:
Role of the CPU : MAIN
CPU position : 20
CPU address : 192.168.1.2
Twin CPU position : 06
Twin CPU address : 192.168.1.3
Redundancy State:
Duplicated configuration : YES
Wished sig. transfer mode : B channel between IO2
Used sig. transfer mode : B channel between IO2
Transmission CPU-CPU : READY
Telephony redundancy : READY
monitel redundancy : READY
memloader redundancy : READY
All applications redundancy : READY
DUAL CPU8 not show Local Main name in Main active CPU !
Re: DUAL CPU8 not show Local Main name in Main active CPU !
This is no issue at all, it will always show the name of the local CPU that is running in main mode.
if you do a ifconfig it will show the ip address of the main though
doublevand981
i connect to main role ip address (192.168.1.4). the CPU name show here should be cpu_m
doublevand981
doublevand981 wrote: ↑04 Nov 2019 01:46i connect to main role ip address (192.168.1.4). the CPU name show here should be cpu_m
No it will never show the main name never has and never will, it will still be in the host table
yep it shows Always the local name
(1)pst_cpu20>
Netmask : 255.255.255.192
| local | Ethernet | pst_cpu20 | 10.235.96.131 |
| local main | Ethernet | main | 10.235.96.130 |
| local | IP/X25 tunnel | x000001_tun | 172.30.253.1 |
| local | Ethernet | pst_cpu6 | 10.235.96.129 |
(1)pst_cpu20>
doublevand981
haroun wrote: ↑05 Nov 2019 03:10 yep it shows Always the local name
(1)pst_cpu20>
Did you check the Dual status ?
Telnet to 10.235.96.130 ip address. it should show name "main"
each time the local name is used instead of "main" wich is the norma behavour cuse like this we know wich cpu is the maindoublevand981 wrote: ↑05 Nov 2019 23:36haroun wrote: ↑05 Nov 2019 03:10 yep it shows Always the local name
(1)pst_cpu20>
(1)pst_cpu20> role
MAIN
(1)pst_cpu20> twin
Wed Nov 6 08:36:18 CET 2019
CPU position : 20
CPU address : 10.235.96.131
Twin CPU address : 10.235.96.129
Redundancy State:
Wished sig. transfer mode : C1 signalling channel
Used sig. transfer mode : C1 signalling channel
bellow i performed a bascul
