8001 not initializing
bugsbunny3
Post by bugsbunny3 »
Hi all, I have some Alcatel8001 phones connected to OXO connect, one of them doesn´t want to boot and stays in "Initializing" phase. I tried to plug it to PoE ethernet port, plug to 5V adapter, plug to adapter 5V without network, nothing helped to start this phone. Is there any chance to boot it from USB for example? Last FW version in phone was V4.2.0.7 11505.
vappleyard
Re: 8001 not initializing
Post by vappleyard »
Hi!
Are you Trying to flash the phone?
If you have access to Alcatel Bussines Portal on Technical Knowledge Center, you may want to see the article titled "8001 desk phone stuck at initializing and not booting"...
https://alcatel-lucent-enterprise.secur ... nel%208001
Regards!
bugsbunny3
Hi Vappleyard, I have access to ALE but link which you put here opens only main ALE web page and I couldn´t find it by name of file, can you send me the file?
usgdaskj
Post by usgdaskj »
I have the same problem with 13 8001G SIP phone and the link above it doesn't work.
any help please ?
gacmuscat
Post by gacmuscat »
I have same issue with lots of units 8001G.more units are going down as days pass by. Has anybody been able to figure out any solution for this issue?
Thanks & regards
Arfath
thunaer86
Post by thunaer86 »
I have the same problem. I have two 8001. Any solution?
hakuna
Post by hakuna »
Anyone find a solution for this? PLEASE HELP
hakuna
Post by hakuna »
Tried the POE injector and was able to save some phones but still quite a lot not working!
sabzalipoor
Post by sabzalipoor »
hakuna
Post by hakuna »
These are dead zombies. no solution.
PoE injectors could save about 2% of these phones.
Return to “Configuration”
